Crystal Mod
Crystal Mod
Hi, does anyone have experience with this in GUFB? I would like to know what needs to be changed in the tune when the crystal is upgraded, please.
Re: Crystal Mod
You swap to a crank trigger and cam sensor and go eec-v
Re: Crystal Mod
Okay, Thanks. I have a couple of Explorer and Mountaineer EEC-V boxes, so I should look for an OEM Ford cam sensor from the Explorer or Mountaineer, or from an earlier model? Which cost effective trigger wheel would you use besides the stock, non SFI unit?
Re: Crystal Mod
99-01 cam sensor is the 2 wire VR type which is what you want
best bet is an 03/04 luxury sedan ecu
I only recommend oem stuff for ignition.
Re: Crystal Mod
Cool, Thanks again for your insight!
