Looking for tuning help on 1996 Bronco AGANF
TexasA&M
- Vehicle Information: 1996 Bronco
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
Bassini Shorty Headers
30lb injectors
Pro-M MAF
Re: Looking for tuning help on 1996 Bronco
Question on the wideband.... What is the downside if it isn't used? I have been looking at how I would install and an issue that I have is that my exhaust has each bank going straight into the first cat, so there isn't a spot to put the sensor that would read both sides of the engine after they combine. Thoughts on how to get around this (or really preferably not use a wideband and save me $200)?
You dont want to read them both combined.
Info is in the pre tune write up.
Nah wideband isnt needed.
TexasA&M
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
30lb injectors
Pro-M MAF
I'll read the pre-tune write-up again. Thanks for the info!
TexasA&M
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
30lb injectors
Pro-M MAF
Donation made! Will work on the info sheet later today and have it ready.
TexasA&M
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
30lb injectors
Pro-M MAF
Going through the checklist now...
Is there any preference on O2 sensors?
What software is needed to datalog with the SCT?
pre tune info write up covers o2s
http://www.efidynotuning.com/pre.htm
sct write up will give you all the details
http://www.efidynotuning.com/sct.htm
TexasA&M
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
30lb injectors
Pro-M MAF
I'll check out the SCT info.
As far as O2s, I saw where it said that new ones are needed but didn't see anything about brand preference. Is there one that works better than the others? If not, I'll get the cheapest and roll out.
ntk's usually last the longest and switch the fastest
they are usually the cheapest too
TexasA&M
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
30lb injectors
Pro-M MAF
Got them on order and have most of the info sheet filled out. When does the premier membership kick in?
