Looking for tuning help on 1996 Bronco AGANF
unlikely
TexasA&M
Vehicle Information: 1996 Bronco
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
Bassini Shorty Headers
30lb injectors
Pro-M MAF
Unread post by TexasA&M »
I pulled the ECU. Which number am I looking for?
Tried posting a picture, but no luck. Anyhow, this is what I see -
ML1-441 ELT0 (largest font)
bar code
Remanufactured FHB---10KR2W
F6PF-12A650-AZA G NPF 03H05
ELT0 is probably the code, not sure which strategy that is though
its on the homepage click on supported ecus
http://efidynotuning.com/downloads.htm
ml1-441 is your hardware code
TexasA&M
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
30lb injectors
Pro-M MAF
I'm guessing that this is the one I want (I apologize for my extreme ignorance)?
[AGANF] 1996-1997 Trucks 4.9/5.0/5.8/7.5 w/ Manual or E4OD transmissions.
I've read through this one the other day but will study it closer now that I know it's for sure the right one.
What will total cost end up looking like if I go with a custom tune? I see $450 for membership and $250 for a quarterhorse... how much is the tune itself? What else, if anything, is needed?
all good no biggie
yep that's it ELT0/TIN3 update is the aganf strategy.
That's all as the tune is free for premium members.
You may want to hold out on the qh though as tunerpro does not currently datalog 2 bank ecus.
You may be better off for the time being just getting an sct xcal 3 and we can remote tune it that way.
Make sure the x3 is unmarried with locks available before getting it.
TexasA&M
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
30lb injectors
Pro-M MAF
That's great! I'll look into the xcal 3. Does it have to be for a Ford?
What will we be lacking with the SCT vs. the QH? Is the tuning process different?
yes
the sct logging is pretty slow and minimal so it wont be perfect but shouldnt have any issues
yep same process
TexasA&M
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
30lb injectors
Pro-M MAF
alright! I'll find a Ford X3 and then make my donation. Out of town for a bit, but hopefully can get this going week after next!
TexasA&M
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
30lb injectors
Pro-M MAF
X3 is on the way! I'll make my donation when I'm back in town next week and we'll get this thing started!
