Which LS plug wires
Re: Which LS plug wires
There we go. Looks like we have everything to do it. I'll order the Ballenger connectors tomorrow probably
Unread post by RinerAuto »
In case you haven't seen this document, it's helpful too. But it's all pigtails.
https://www.fordservicecontent.com/pubs ... atalog.pdf
I'm trying to find the manufacturer part number of the connector, to see if I can find it cheaper. I like Ballenger, but $72 for 8 connectors is high. But they have done all the hard work of supplying terminals and seals. (Also just realized Ballenger is 2 hours from me).
Edit: I think I figured out its a TE MCON 1.2 housing (or at least similar enough to). Unfortunately it seems the keyway option the coils use (between pin 2 and 3) is the one that is restricted or out of stock at TE and distributors. So at this time it looks like Ballenger is only option.
https://www.te.com/commerce/DocumentDel ... -1718644-1
Yeah, it sounds like we found the pigtails. I agree 9$ a piece is expensive but im not that worried about it. My coils should be in stock this week and I should have them sometime next week or the following week. Hopefully before February. Im getting really close to having all the parts to get this beast started.
