Hello,
What can cause Mustang Coyote Gen2 to through an error code P0304 and P0316 ?
Can a tune cause it or it's mechanical failure such as ignition coil, spark plug or internal failure in Cylinder 4?
Thanks.
Mustang GT VMP Odin Supercharger Misfire in Cylinder 4
- Vehicle Information: 2001 Mustang Roush Stage 3 Supercharged with Build Engine
Re: Mustang GT VMP Odin Supercharger Misfire in Cylinder 4
if its just two cylinders then its a mechanical misfire
do a crank relearn just to be sure
We did a crank relearn and still same issue. We contacted SCT Tech and the said “it could be a checksum missing or miscalculated after the flash and they said they have seen that more than once and it’s a Ford issue.”
Is there away to try in the tune to see if it will help not detecting the misfire in Cylinder 4 ? At least to try and see.
Just to let you know that when we get the spark plug from cylinder 4 it was rich ( black color ) while the others are fine.
yeah I would expect as much
