Easy way to create xdf files
Is there an easy way to create xdf files after disassembly?
I have a bin file that is disassembled:
  • 100% function,
    90% tables
    60% scalars
Is creating an XDF completely manual?
Re: Easy way to create xdf files
yep only way to do it
rzasa is my master xdf
I copy and paste the function and update the address. Makes life significantly easier.
There is a sad2xdf application floating around someone made but it doesnt use rzasa as a template so its been rather useless.
motorhead1991
Vehicle Information: 1990 Ford Ranger commercial:
1990 Ford Ranger Custom:
Unread post by motorhead1991 »
SAD806x has a utility to export to an XDF but you'll have to organize it all manually. I don't remember if it can also do the equations and stuff though
