[EEC Master Hardware List]
Threads for specific write ups as a revision history and to notify of write up updates.
http://www.efidynotuning.com/downloads.htm
Everyone including myself can appreciate the newly updated EEC Master Hardware LIst. Previously this was all grouped by strats and in a thread on the old forum. I've been meaning to break it out to its own post that's easily accessible on mobile when not connected to the internet and I went a step above and beyond and put a search box there to significantly simplify life as well as not clutter up things with all the non-necessities.
In any case try out the new search bar and enjoy.
You can put in the strategy name or hardware cal code for the ecu you have and very easily and quickly see what strategy supports it.
If there's anything missing please do post back here and i'll add it in. Also, I have very minimal eec-iv hardware codes in there so if anyone has any info please do post it here and i'll add it in as well.
As you can see by the link I merged the hardware list with the downloads as that's the most practical need for it when looking for the files to snatch.
Re: [EEC Master Hardware List]
The description for A1C and C9C1 needs to be swapped:
EFI-SD2x vs EFISD4x....
Ah yes that's a keen observation. Corrected. I'll post it tonight thanks.
Would you happen to have a list of eec-iv hardware codes ?
decipha wrote: 2021 Mar 03, 07:19 Would you happen to have a list of eec-iv hardware codes ?
I do, about ~330 of them. Most are EEC-V
You looking for SD48, SD47, SD20,...., SMD...,SFI-MA,... that sort of thing?
I think an online database is in order to keep it current and up to date.
motorhead1991
Vehicle Information: 1990 Ford Ranger commercial:
1990 Ford Ranger Custom:
Unread post by motorhead1991 »
wwhite wrote: 2021 Mar 03, 19:26
I actually have such a thing started...
thats what im asking for
hence the search bar in the link in the OP
The links for A1C and C9C1 needs to be swapped, A1C links to C9C1, and C9C1 links to A1C.
i see the error thanks
corrected thanks again
