Part throttle timing and boost
Unread postby 351pwrdstang » Sat May 05, 2018 8:42 am
351w 78mm on a 7psi spring makes full boost without going wot. I do have to push on the pedal a bit but no where near wot. I reduced the timing in the higher load cells to give me 20* is this acceptable?
The wot map is 18* around same rpm. Vortech built boost gradually at wot only. This thing makes full boost whenever I want. Looking over the log I see I am still in PT while making boost and wasn't sure how much timing needs to be removed. Vic Jr's. I was forcing OL while getting fuel dialed in and want to put her back in closed loop but do I need to make sure we go open loop if it builds boost at these lower throttle angles. Also this is preliminary tuning and will eventually be switching to as much as a 14psi spring.
351pwrdstang
Vehicle Information: 351w T trim 87 mustang GT A9l tuner pro moates qh
Vehicle 2 Information: 331s trim 93 notch tuner pro moates qh
Re: Part throttle timing and boost
Unread postby decipha » Sat May 05, 2018 12:41 pm
yep thats fine no prob
at 0 vac / 0 boost make sure u dont exceed mbt timing
as it progresses more in to boost you should have the timing ramping down
I usually switch out of closed loop at 3-4ish lbs of boost. By setting fn320a the perload threshold to 1.20 to go open loop and having fn035 the peak n/a load function dialed in you shouldnt have any problems and it should transition in to OL at 1.2 perload == 3.5 lbs of boost roughly
that should be the stock value in the a9l2 if memory serves
Unread postby 351pwrdstang » Mon May 07, 2018 11:14 am
Seems to be a lot of confusion surrounding the fn035. I left mine the same from when I had the blower on it as I don't know to bypass boost on a turbo car. Manually open the waste gate ?? We did change the cam so I'm sure its off now. At 7psi I'm in the 130's perload. I want to change springs soon do i need to yank more timing at PT if its gonna hit 14psi or close to it. Wot is locked at 18 until I get it on the dyno.
351pwrdstang
Return to Foxbody Tuning
Users browsing this forum: Exabot [Bot] and 0 guests
