M0M2 (EFI-MA35C) Development & Discussion
Re: M0M2 (EFI-MA35C) Development & Discussion
Unread postby jsa » Thu Nov 16, 2017 6:06 pm
Pym has issues with SAD and Rbase as well.
viewtopic.php?f=30&t=1260&p=32530&hilit=rbase#p32530
Cheers
John
Power Poster
EEC-IV GHAJ0 ANTI or COSY
Unread postby motorhead1991 » Thu Nov 16, 2017 7:01 pm
That just might be my issue. This is for a '90, which is "early" in a sense.
It is however the first year of the MAF 2.3, and only in California :D
motorhead1991
Unread postby jsa » Thu Nov 16, 2017 7:14 pm
M0M2 in anyway related to LA3 and LA4 catch code?
Cheers
John
Power Poster
Unread postby motorhead1991 » Thu Nov 16, 2017 8:04 pm
jsa wrote:MOM2 in anyway related to LA3 and LA4 catch code?
Aside from being for a 2.3, I don't believe so, but like decipha always says "Henry loved to reuse code."
I know LA3 only had one slope scalar, and that might be the case here as well
motorhead1991
Unread postby jsa » Thu Nov 16, 2017 8:39 pm
Archived somewhere here I have LA3 & LA4 directives and listings that were done with the BL disassembler.
Let me know if you want them and I can dig them up.
Cheers
John
Power Poster
Unread postby motorhead1991 » Thu Nov 16, 2017 8:40 pm
jsa wrote:Archived somewhere here I have LA3 & LA4 directives and listings that were done with the BL disassembler.
Anything helps. This ECM seems to be quite a headache :D.
I might have enough done through SAD to create one, but the formatting is quite a bit different.
motorhead1991
Unread postby motorhead1991 » Thu Nov 16, 2017 9:09 pm
Well, both slopes are defined, but the high slope is also pointing at a KAM address. So, that means the index pointers aren't being extrapolated correctly as decipha thought.
motorhead1991
Unread postby jsa » Fri Nov 17, 2017 2:34 am
Courtesy of the Andrew March website.
LA3 and LA4 disassembly.
Cheers
John
Power Poster
Unread postby ranga83 » Fri Nov 17, 2017 2:40 am
Our aussie 4.0s only have the 1 injector slope too. Ill find it in my dis and see if its similar
ranga83
Power Poster
Vehicle Information: 1996 EF Falcon 4.0 inline 6, 4TAD ecu, tunerpro, and moates q/h
Unread postby motorhead1991 » Fri Nov 17, 2017 11:05 am
ranga83 wrote:Our aussie 4.0s only have the 1 injector slope too. Ill find it in my dis and see if its similar
I found both slope pointers, when compared to A9L. The problem is that they don't resolve to an address.
M0M2 is older than A9L, so it makes sense why the code would be different, and coupled with the fact that its a "California" computer makes it an oddity as well.
Note: California is probably the strictest state when it comes to emissions standards. Most "efficiency" tweaks from an OEM start as a California compliant model. Like the cam synchronizer and MAF on the 2.3s.
motorhead1991
Unread postby sailorbob » Fri Nov 17, 2017 11:32 am
The high and low injector slopes are in data block 3 (both are set to the same value of 14.22 lb/hr in M0M2). This strategy, and similar strategies (such as used by the C1A1 & ANY1 ecu's), copy the slope values into ram and use them from those ram addresses as both the original value and also as a hot injector compensated value if required.
sailorbob
Tuning Extraordinaire
Unread postby motorhead1991 » Fri Nov 17, 2017 11:44 am
sailorbob wrote:The high and low injector slopes are in data block 3 (both are set to the same value of 14.22 lb/hr in MOM2). This strategy, and similar strategies (such as used by the C1A1 & ANY1 ecu's), copy the slope values into ram and use them from those ram addresses as both the original value and also as a hot injector compensated value if required.
MOM2 and M0M2 are different. MOM2 is an OBD2 computer as Mike and I have discussed in private.
motorhead1991
Unread postby sailorbob » Fri Nov 17, 2017 12:07 pm
I've fixed my misspelling of M0M2 :D
sailorbob
Unread postby motorhead1991 » Fri Nov 17, 2017 12:31 pm
sailorbob wrote:I've fixed my misspelling of M0M2 :D
So you have a def already? Or just experience with this binary?
motorhead1991
Unread postby motorhead1991 » Fri Nov 17, 2017 1:09 pm
Ah ha! I've figured it out. Under "Reset_All", it lists an address, then a RAM pointer. This means the slopes are 9d94 and 9d96. Thank's for the hint, Derek :D
motorhead1991
Unread postby sailorbob » Fri Nov 17, 2017 2:46 pm
I don't have a definition for it, I just compared the binary to another EFI-MA39C ecu I have disassembled. Yep, you've found the slopes.
sailorbob
Unread postby motorhead1991 » Fri Nov 17, 2017 4:06 pm
sailorbob wrote:I don't have a definition for it, I just compared the binary to another EFI-MA39C ecu I have disassembled. Yep, you've found the slopes.
Sweet, so my work on this might open the door to the other early MAF ECMs :D.
motorhead1991
Unread postby motorhead1991 » Sat Nov 18, 2017 11:24 pm
Now we're getting somewhere with this...
Just a few more fuel scalars and tables to locate, then it's on to figuring out spark or idle, and the rest of the not-so-important stuff.
motorhead1991
Unread postby sailorbob » Sun Dec 17, 2017 2:55 am
If your disassembly is spitting this out in your listing
6465: a3,76,96,22       ldw   R22,[R76+96]   ALTSTACK = [316];
then it's either wrongly set to treat the binary as 8065 based instead of 8061 based, it's wrongly labelling a general register or you have it mislabelled in your directive file.
sailorbob
Unread postby motorhead1991 » Mon Dec 18, 2017 12:24 pm
sailorbob wrote:If your disassembly is spitting this out in your listing
No "H" option set, so I'd bank on the directive file. Being the less experienced one here, I'd never notice errors like that. What's wrong with it specifically?
motorhead1991
Unread postby sailorbob » Mon Dec 18, 2017 12:36 pm
The 8061 does not have an alternative stack pointer.
sailorbob
Unread postby motorhead1991 » Mon Dec 18, 2017 1:35 pm
sailorbob wrote:The 8061 does not have an alternative stack pointer.
Well that would make sense then wouldn't it? :D
That is in-fact mislabeled in the directive.
motorhead1991
Unread postby motorhead1991 » Thu Jan 11, 2018 11:41 pm
Updated the files and changed the zip name with a timestamp this time.
m0m2_1-11-18
The XDF has a few more things identified, and is almost inline with the directive. There are some minor discrepancies still, but it's getting closer.
Also laid out are some of the RAM pointers. I need to update the datalog patch code to coincide with those though.
EDIT:
Am I also correct in assuming these early MAF ECMs didn't use halffuelon (NRM_SH)? The hex value at this address is FAFE.
motorhead1991
Unread postby motorhead1991 » Sat Jan 13, 2018 11:52 am
I intend on updating some files in the above zip tonight. For the 5 of you that downloaded it, compare the dates on them. I fixed the base fuel table and transients on the XDF, as well as added the PIP RPM limiters.
motorhead1991
Unread postby motorhead1991 » Thu Jan 18, 2018 11:37 am
Another updated zip, this time with the beginning of a changelog. The datalog patch code is almost ready as well (BTW decipha, your A9L patch still has ECT in list A, which is not what your writeup says to do).
Nothing real major as far as the tune is concerned, but the disassembly has a handful of updates.
m0m2_1-17-18
motorhead1991
Unread postby decipha » Thu Jan 18, 2018 7:48 pm
motorhead1991 wrote:... (BTW decipha, your A9L patch still has ECT in list A, which is not what your writeup says to do)
thats cuz in gufb the ect is b0 and act is b1
the logging offset puts them in that order as well at 1f24 and 1f25
instead of copying a byte from b0 to 1f24 and a byte from b1 to 1f25 you might as well save a word from b0 to 1f24 which does the same
Unread postby motorhead1991 » Thu Jan 18, 2018 8:12 pm
Makes sense. My guess is M0M2 should also be fine in this case, since ECT and ACT are at AD and AE respectively.
motorhead1991
Unread postby decipha » Thu Jan 18, 2018 8:32 pm
nope wont work, AD is an odd address boundary, if u read a word from an odd address you offset the reading address
youll have to read them each in list b as bytes each
Unread postby motorhead1991 » Thu Jan 18, 2018 9:52 pm
OK, so "EE20" is where list B starts on this table. If I'm understanding correctly, the shadow address is more important than the physical address of the pointer, yes? So if I push list C further down the ROM, it shouldn't break.
motorhead1991
Unread postby decipha » Thu Jan 18, 2018 10:09 pm
ee20 is the rom address, i only put that there so its easier to compare when you have a hex editor open, u can ignore it
you simply place the byte address and shadow location after the word list, i usually like to keep things in order
if u look at rzasa or the like youll see instead of having the payload list as a table i have it as a function instead, makes it very easy to simply copy and paste when u need to add space in there
Unread postby motorhead1991 » Sun Feb 04, 2018 6:42 pm
Got some quality time with the QH to try the datalogging patch. The addresses need work, but it's logging!
https://youtu.be/FN006nk-miU
motorhead1991
Unread postby decipha » Sun Feb 04, 2018 8:36 pm
oh good
Unread postby motorhead1991 » Sun Feb 04, 2018 11:10 pm
I figured it out. I forgot to update the patch itself, and reset the binary. Oops :D
motorhead1991
Unread postby motorhead1991 » Fri Nov 30, 2018 6:36 pm
All right, so since my quarterhorse is tied up with the turbo truck, I enlisted some help to get the data logging patch squared away. Following the list on the disassembly writeup and my own disassembly, I was able to get the payload list somewhat put together, but none of the values are showing correctly if it all. I can provide the tune xdf and a video here shortly.
(Using with 11/9/17 ADX)
motorhead1991
Unread postby decipha » Fri Nov 30, 2018 6:59 pm
I need 5 things
1) your current unpatched no logging code bin
2) your xdf
3) the console code address or location where u want to inject the call to the patch code
4 & 5) your dir and cmt disassembly files
and if u feel up to it, the ops list for the pids to log in the correct order if u feel up to it
Unread postby motorhead1991 » Fri Nov 30, 2018 8:09 pm
decipha wrote:I need 5 things
2) your xdf
I actually have the code injecting fine, but the values are all goofy... Let me clear the patch though and get you a "clean" bin. There is a file with addresses for the datalogging code, as well as the dir file (No cmt yet).
http://developer-aa51.com/.binaries/datalog_issues.zip
motorhead1991
Unread postby motorhead1991 » Mon Dec 03, 2018 11:41 pm
Somehow, some way, I managed to get normal readings from ACT and ECT, as well as ATMR and VSBART, but that's it.
motorhead1991
Unread postby motorhead1991 » Wed Dec 05, 2018 7:40 pm
OK, so... The ADX I had was the cause of the frustration. I downloaded a fresh one, moved a couple things around and now things are showing sane values. Glad this fight is almost over... :D
motorhead1991
Unread postby motorhead1991 » Mon Dec 10, 2018 9:05 pm
I've been trying to button up the last bits of the patch before I'm satisfied with it, but here's what I have so far:
M0M2 Datalogging
motorhead1991
Unread postby motorhead1991 » Wed Jan 09, 2019 12:12 am
Found the ISC transfer, fixed the majority of the function listings on "msg" and added the fuel pump prime hack to the XDF
motorhead1991
PreviousNext
cron
