EEC-V harness fab? No problem anymore!
ECU Diagnostics, Discussions, and Support
Unread postby ironmanisanemic » Fri Aug 05, 2016 12:13 am
So i have been able to finally identify the TYCO part numbers for the 104pin connector so you no longer need to rely on junk yard parts.
Female Terminal - F4SB-14487-AA or XL2T-14487-AA - 776235-1 sourced from onlinecomponents.com
ECU Connector End (solders to the pcb) - F5SB-14A624-AA - 770750-1 sourced from onlinecomponents.com minimum order quantity of 6
Harness Connector End(bolts to the ecu) - F5SB-14A464-AA - 776557-1 sourced from onlinecomponents.com minimum order quantity of 48 (i ordered these from connectorpeople.com, they have them in stock but have a $25 dollar minimum. i ended up ordering 6 of them for just over that.)
Gasket - 776237-1 - sourced from onlinecomponents.com minimum order quantity of 625
Housing cover (strain relief) - 770768-1 - sourced from onlinecomponents.com
All of the part numbers listed AFTER the Ford numbers are the TE Connectivity numbers (formerly Tyco Electronics). Those should be able to be sourced virtually anywhere.
I am still looking for vendors for the few parts that have to be purchased in bulk.
EDIT
Added tech docs and tech drawings
ironmanisanemic
A+ Contributor
Vehicle Information: 89 Ford Bronco - 393W, Professional Products 190cc heads, Custom Comp Cams hyd roller cam, Edelbrock EFI Mustang intake, 10:1 compression, FRPP LU34 34LB injectors, ProM 80mm Mass Air Meter, 2-1/2" into 3" y pipe, no cat, and hooker aerochamber muffler. U4P0 computer with Quarterhorse and BE, EA. 4R70W
Re: EEC-V harness fab? No problem anymore!
Unread postby jsa » Fri Aug 05, 2016 1:11 pm
Excellent. Thank you for sharing.
Cheers
John
Power Poster
EEC-IV GHAJ0
ANTI, COSY, QUIK or CARD
SMD-490, SMD-190
Unread postby decipha » Fri Aug 05, 2016 1:17 pm
excellent work miles, hopefully others that come searching will benefit from your efforts
stickied
Name: Michael Decipha Ponto
06 Chrysler 300 AWD
Unread postby ironmanisanemic » Fri Aug 12, 2016 10:22 pm
So i finally got the terminals and the connectors in that i ordered. They are exactly what they appeared to be in the tech drawings. I have attached a few pictures.
Also, I was informed by the folks at connectorpeople.com when i ordered the connectors that they have a different part number for the terminals that go in it. They sent me a small sample of them to compare to the ones i purchased from onlinecomponents.com. They are identical, even though they are different part numbers. The best part is... THEY ARE WAY CHEAPER!
Lets break this down.
Part number 776235-1 (first number I had found) sourced from onlinecomponents.com cost $0.386 each. No minimum quantity, only minimum $50 purchase. If you only buy these from them you get 130 terminals for the minimum purchase amount.
Part number 776326-1 (new number i was given) sourced from connectorpeople.com cost $0.121 each. Minimum of 83 to be purchased at a time, also has a minimum $25 purchase. If you only buy these from them you get 207 terminals for the minimum purchase amount.
If you buy the terminals and the housing from connector people, you can save on shipping, and save money. The housing from connector people is only $4.99 each. But you have to buy a minimum of 3.
Lets say you buy the 3, thats $14.97, then you get 300 terminals so you have 100 per housing and that will probably give you some left overs since not every position is filled. So thats an extra $36.30. So for $51.27 plus freight and tax, you get what you need plus spares that you could unload on ebay if you so choose.
I know that this is a way cheaper option considering that mass-air.com sells the bare connector on ebay for $59.95 plus shipping, and if you want it with terminals its $149.95 plus shipping. They also will NOT sell you just the terminals.
ironmanisanemic
A+ Contributor
Unread postby yeastieBoB » Sat Aug 13, 2016 4:46 pm
That is really great information. Thanks for taking the time to share.
yeastieBoB
Power Poster
Unread postby zslash28 » Sun Mar 26, 2017 12:00 pm
I have been searching and searching for quite some time. Came across your previous thread and thought the trail had gone dead. Thank you for sticking with it, and posting this information. Looks like the female terminals are on back order until June of 2017. Fingers crossed I can get my hands on enough to build my harness in a few months.
zslash28
User
Vehicle Information: 1972 Ford F100. Has 2004 Mach 1 Engine. Ford EEC-V with factory tuning.
Unread postby ironmanisanemic » Sun Mar 26, 2017 1:56 pm
Man, connector people had a ton of both of the part numbers for the terminals, but someone cleaned them out! Should have done that myself... Oh well. Good luck on the hunt. Let me know if you find a new source of them.
ironmanisanemic
A+ Contributor
Unread postby haroldk » Wed Jan 24, 2018 10:20 am
Just wanted to post an update. Looks like TE discontinued the female pins for the EEC-V connector. I haven't been able to find them in stock anywhere and no part number that supersedes it.
haroldk
A+ Contributor
Name: Chris Kachelmyer
Vehicle Information: 1984 Porsche 944
Ford 5.0
CDAN4/ZXA5
Quarterhorse
Unread postby decipha » Wed Jan 24, 2018 12:09 pm
that rly blowes the meat whistle, hopefully someone picks up the slack some time soon, I was thinking of ordering some myself
06 Chrysler 300 AWD
Unread postby motorhead1991 » Wed Jan 24, 2018 8:34 pm
Following thus... I might make my own OBD2 conversion harness for gen2 Rangers :D.
I've found the wedgelocks from au-ve-co for building pigtails, if that's not already known.
motorhead1991
Vehicle 2 Information: Stock 1990 Ranger. ICM relocation, Volvo 31lb Bosch injectors, custom tune, e85: 82hp/103tq
Unread postby ironmanisanemic » Wed Jan 24, 2018 9:34 pm
Those ones that auveco offers are the same ones that everyone else offers. They are either too big or too small for the eec-iv connector, and there are none of them that are even close to working with the eec-v.
ironmanisanemic
A+ Contributor
Unread postby motorhead1991 » Wed Jan 24, 2018 9:45 pm
ironmanisanemic wrote:Those ones that auveco offers are the same ones that everyone else offers. They are either too big or too small for the eec-iv connector, and there are none of them that are even close to working with the eec-v.
Right, they're for sensors and chassis connections. Still a part of the harness, but not directly related to the ECM connector.
motorhead1991
Unread postby 93BlueFoxGT » Wed Jan 31, 2018 7:40 am
Is this the only option now for connector and terminals? https://www.ebay.com/itm/291392744209
93BlueFoxGT
Vehicle Information: 93 Mustang GT
A3M ECU with A9L2/GUFX, Moates Quarterhorse, Tunerpro RT
Stock 95k mile Long Block, 70mm TB, Explorer Intake, Custom Slot MAF,
BBK 1.625" Longtubes, 2.5" DR. Gas offroad x-pipe, Magnaflow catback.
Stock T5/3.08 rear
Return to ECU Discussions
cron
