CDAN4 Injectors Slopes
Unread postby galaxis » Thu Sep 28, 2017 4:31 pm
As far as I can tell from personal experience and from reading online, CDAN4 ecus don't appear to handle large injector slopes properly.
Here's my situation:
Cobra 39# injectors & 90MM LMAF
4.6 2v PI heads with SVO supercharger CDAN4 BE2012 Sailorbob strategy
No matter how high I set the slopes in my calibration, my car runs ~20% rich unless I change my MAF flow to account for it. I know that a stock LMAF transfer likely won't be perfect for me, but being pretty consistently 15-20% off across the board seems suspicious.
The other cue to me that changing the MAF is lying to the car: my load values are lower than I expect. With no blower, stock injectors, and multiple different MAFs I used to see somewhere around 95 MAX load in a pull on a good day. Now I see somwwhere around 90 load at like 7psi of boost; my 0 boost 0 vac load is around 65.
I have NO other scaling in my tune (my displacement parameter is my ACTUAL displacement, etc.)
As far as I can tell, the SCT tune I have also does this.
I guess I just want to make sure I'm following 'best practice' and not missing a better solution.
galaxis
Vehicle Information: PI Swapped '96 Thunderbird
Re: CDAN4 Injectors Slopes
Unread postby decipha » Thu Sep 28, 2017 8:23 pm
yea the clockconversion clips the max slope value on all eec Vs
when i get to my laptop i can tell u the exact value
best to scale it in half i always do
Unread postby galaxis » Thu Sep 28, 2017 8:41 pm
Okay it just clips it at some point?
So if you scale everything down enough, it brings your injector slopes back into the non-clipped, valid range of adjustment...
And 50% is easy to work with.
I think I'm definitely going to give this a try; thanks
galaxis
Unread postby sailorbob » Fri Sep 29, 2017 4:38 am
The CDAN4 injector size limit is 40.23 lb/hr.
sailorbob
Tuning Extraordinaire
Unread postby shine1stang » Wed Oct 04, 2017 5:15 pm
sailorbob wrote:The CDAN4 injector size limit is 40.23 lb/hr.
so the values higher than 40.23 aren't recognized by the ecu? are we talking about Alosl injector low slope? I have mine set to 101.46 the 80lb value. Ive got a pretty good running tune on my car and have taken a few wot rips since going with the qh. all seemed well though
shine1stang
Vehicle Information: 1997 Mustang [CDAN4]
4.3L V6 Forged bottom end, small cam, ported heads, sheet metal intake C4 transmission
Tma Turbo Kit w 6765hp precision turbo 20lbs boost
best 1/8 6.85@101.94mph
best 1/4 10.71@125.69
Currently making the switch from SCT prp to BE
Unread postby decipha » Wed Oct 04, 2017 10:18 pm
correct, the ecu cant calculate a slope that high, anything above 40 will return the same value that the ecu uses
yea all will be well, u can dial in anything, but if u want the true injector values in there youll have to scale it back
on cdan4 i always divide the injector values and maf by 3 to get it under the max slope
Unread postby motorhead1991 » Thu Oct 05, 2017 12:05 am
Taking notes, since I'll have to do this on FLH2 as well. Perhaps that's why I had o pull so much from the offset table...
motorhead1991
Unread postby shine1stang » Thu Oct 05, 2017 1:36 pm
decipha wrote:correct, the ecu cant calculate a slope that high, anything above 40 will return the same value that the ecu uses
will i have to scale anything else? just high/low slope and maf? Or should i just scale everything>vlt offset, breakpoint,displacement ect?
shine1stang
Unread postby decipha » Thu Oct 05, 2017 1:39 pm
the offset isnt affected by scaling leave it be
u have to scale the breakpoint though
if the engine is going to be making a lot of boost then leave sarchg be and scale perload (fn035) and the spark table load scaling, otherwise, scale sarchg down too
Return to EEC-V & SN95 Tuning
Users browsing this forum: No registered users and 25 guests
