flex fuel hack?
Tuning for alternate fuels such as: CNG / LPG, Ethanol (E-85), Methanol, etc...
flex fuel hack?
Unread postby Pappacosworth » Fri Sep 08, 2017 12:18 pm
Innovate has new 4in1 meter that has analog outputs. One of them is ethanol content "Brown wire: Ethanol % 0V = 0% Ethanol 5V = 100% Ethanol"
I thought can this be used to control fuel multiplier to control fuel amount in ratio to ethanol?
Pappacosworth
Fabricator
Re: flex fuel hack?
Unread postby SlowBox » Fri Sep 08, 2017 2:14 pm
I don't know of a way other than just using that information to set z_afr.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: flex fuel hack?
Unread postby jsa » Fri Sep 08, 2017 10:34 pm
Could also change hi and lo slope.
Cheers
John
Power Poster
EEC-IV GHAJ0
ANTI, COSY, QUIK or CARD
Re: flex fuel hack?
Unread postby Pappacosworth » Sat Sep 09, 2017 12:18 am
I meant realtime correction, like in Ford Flexfuel models.
Pappacosworth
Fabricator
Re: flex fuel hack?
Unread postby decipha » Sat Sep 09, 2017 2:50 am
yes it can be done, requires someone writing the code to do it
its a bit more involved than that, the AFR scalar, crank pw, target lambda, transient fuel, and spark advance also need to be adjusted at a minimum
thats something i worked on but had no need nor desire to finish as of yet, in the near future i hope ill be getting back to it
youd need a superlogger to get the values piped into the QH, some QH firmware code needs to be written there to have a fresh set of values updated every loop and accessible on the mbus for the ecu to have access to it
Name: Michael Decipha Ponto
Re: flex fuel hack?
Unread postby jsa » Sat Sep 09, 2017 4:05 am
Yes realtime. But how often does the fuel change composition?
Also thinking along the lines of superlogger.
Question is how often does your strategy read slope values or z afr?
Slope values are relevant to a particular viscosity fluid. How does bio fuel viscosity vary from unleaded?
Cheers
John
Power Poster
EEC-IV GHAJ0
Re: flex fuel hack?
Unread postby Pappacosworth » Sat Sep 09, 2017 6:23 am
One way could be to use flexfuel ecm from suitable Ford.
Pappacosworth
Fabricator
Re: flex fuel hack?
Unread postby decipha » Sat Sep 09, 2017 11:40 pm
yea could do that too
fuel make up changes quite a bit when topping off with an alternate fuel, as the pump runs and recircs the fuel it mixes it more
correct, slopes are not usually affected by alternate fuels mostly the stoich AFR
Return to Alternate Fuel Tuning
