Below is a hardware list of hardware codes and strategies, this is extremely useful for knowing what you can use on which ecu hardware
here is a link to check the most up to date ford calibration for a given catch code, also shows the hardware code as well
http://www.obdtester.com/ford-ecu-update/http://www.obdtester.com/ford-ecu-info/why is this important? well disassembly is no easy process and that in itself is pretty time consuming then writing a def file and keeping up with datalogging etc... can be a bit tedious, this list will show which hardware codes are support by which strategies therefore its absolutely useless to disassemble more then one strategy within the same group since they are the same, hopefully this will help out the DIY community so we can focus on supporting a vast majority of the hardware and not have to focus on specific strategies.
I've compiled this list myself over the years tuning different setups so most of the info here is correct but if you find anything that isn't please note it so it can be corrected.
96-97 Mustang (2 bank)
CDAN4 codes
ML2-304 (v6)
ML2-334
ML2-335
ML2-309 (v6)
covers CDANA, CDAN3
98 mustang - 4 BANK
CRAJ0 Codes
ML2-872 (v8)
ML2-891 (v6)
possibly below is 4 bank
covers CRAI8, CRAI5,
should support ML2-871
works with CRAIA, CRAIB, CRAIC, CRAI9
MLC-411, MLC-441, CXAB1, CXAB2, CXAB3
99-01 mustang
CVAF1 codes
MLC-461
MLC-462
covers CVAE7, CVAE6, RVAD0, RVAF1, RVAF2, RVAF3,
Late 01 Mustang, kind of a bastard, FBGI0 will run it fine UNTIL it throws codes. CVAF1 will throw bad coil codes.
RVAFA, RVAFB
MLC-463 ??
MNAE0 codes - 99 & 00 Lightning
MLC-482
MLC-481 - POSSIBLY MLC-481A
MLC-491
does not work for MLC-482A (04-L) as the pin mapping required recoding
covers MRAD3, MRAC0, MRAD2, MBAI3, MBAI5, MBAI7, MBAI9, MBAIB, MBAJ2,
MBAJ3, RDAB8, RDABB, RDABC, RDABD, RCAB0 ?
MLC-482A - 04 Lightning TAUF0 / URB1 - independent strategy
02-03 Mustang V8 - Can be replaced with FBGI0
MPC-14A
MPC-14B
MPC-14D
MPC-14E
MPC-14F
MPC-14G
covers RYAC2, RYAE0, RYAF0, RYAF1, RYAK0, RYAK1
03-04 cobra
FBGI0 codes
MPC-14C
covers RYBD0, RYBE0, RYBE1, RYBE2, FBFG2
FBGH0 too?
99-03 5.4L w/ 4R100 E-SERIES, F-SERIES, EXCURSION, EXPEDITION, NAVIGATOR
MZAK0 codes
MLC-496, MLC-496A, MLC-497, MLC-421, MLC-422, MTC-321, MTC-322, MTC-323
MTC-331, MTC-421, MTC-421A, MTC-422, MTC-423, MTC-431, MTC-301, MTC-302
Covers
MMAC0, MMAD0, MMAF1, MMAH0, MMBB0, MPAJ0, MPAK0, MPAL1, MPAL3, MPAL4
MPAL5, MPAL6, MPLAB, MPALC, MZAD1, MZAE0, MZAG0, MZAG1, MZAH0, OIAE1, OIAG0,
OIAH0, RFAH1, RFAH5, RFAH6, RHAG1, RHAG6, RHAG7, RHAG8, RHAGB, RIAE0, RIAH0, RIAI0, RIAI2
MMAGA, MPAM0, MPAM1, MPAMA, MZAD2, MAAG2, MAAG4, MZAK0
02 LINCOLN NAVIGATOR / BLACKWOOD & 01 F-150 - 4R100
MQAH1 codes (can run FBGI0 w/ manual or 4R70W)
MPC-141
covers (4r70w and 4r100 mixed)
MQAI0, MQAF0, MQBH1, MQAI1, RWAF0, RWAI0, RWAI1, MQAH1 (4r100), RWAI2 (4r70w)
95 RANGER
AJAP2 codes
ML2-202, ML2-101, ML2-102, ML2-201
covers AJAP3, AJAP4, AJAP5,
96 RANGER
AJAQ5 codes
ML2-112, ML2-111, ML2-211, ML2-212
covers AJAQ4, AJAQ3, AJAQ5
Note: Uses dual coil packs with offset staggered ignition
2001 - 2003 Ranger / Explorer / Mazda B-Series 3.0L & 4.0L
MP2-111, MP2-112, MP2-113, MP2-114
covers
peav1, peav6, peaw7, pyaec, pyaed, pyaf1, pybd2, pybb0, pybd3, pycl7
pybd0, pyaf5, pyaf2, pyae1, pyaea, pyad0, pyac0, peav2, peav4, peaw0
peaw1, peaw2, peav3, peav8, peav9, peap1, peas0
2006 Ranger 2.3L EEC-V (last year)
MP2-25B hardware code
Cal Code XNV0 - Manual Trans
PRDO0 Strategy
appears to be an independent strategy
Note: uses only 1 coil pack with no anti theft
01-03 LIGHTNING & 02-03 HARLEY
OMAE2 codes - note OMAE2 is missing the 4.0 clock index table, can be added in
MPC-206
covers OMAE1, OMAD4, OMAD3, OMAD2, OMAD0, OMAC0,
MAYBE MPC-205 & 204 - ODAL1, ODAI0
2002 F-150 4.6L 4x4
ODAJ0 codes
MPC-201, MPC-207, MPC-202
covers
OCAF0, OCAH0, OCAJA, OCAL0, OCAM0, OCCB0, ODAG0, OCAJ0
03-04 Crown Vic / Grand Marquis / Marauder
RZASA codes
MPC-175, MPC-176, MPC-177, MPC-178, MPC-185, MPC-186,
MPC-187, MPC-188, MPC-195, MPC-196,MPC-197, MPC-198,
covers
RZAO0, RZAO1, RZAO2, RZAM0, RZAN0, RZAR1, RZAS0, RZASA
RZAU1, RZAU0
note: although these ecus can run the FBxxx tunes, these ecus physically do not
have fan outputs nor a starter interrupt output if not used factory equipped in the ecu.
03 Crown vic / Town Car / Grand Marquis
RZAJ0 codes
MPC-155, MPC-156, MPC-157
Note: same notes apply as rzasa, can prob run RZASA
1996-1997.5 Explorer & Mountaineer 5L
CQAB3 codes - (2 bank)
ML2-4D1, ML2-336
covers
CQAB0, CQAB1, CQAB2, CQAB3, CTBAE, CTBAF, CTAAA, CTAAD,
98 E-Series / EXPLORER/ MOUNTAINEER - (4 bank)
CJAB1 codes
ML2-451, ML2-431, ML2-432, ML2-473
covers
CPAI1, CJAB0, CPAF3, CPAGB, CPAIA, CPAIB, CPAF4
CPAI3, RAAD3, RAAD4, RAAD0,
97 F-150
CTAA8 codes (2 bank)
ML2-331, ML2-332, ML2-352, ML2-353
covers
CTAA5, CTAA1, CTAA7, CTAA8, CTAA6
can possibly run a cdan4 tune if configured properly
00 EXPLORER
REAC3
REAC4 - ML2-8A1
READ0 - ML2-8A1
Note: appears strat is for EQE3 tune only
