HSF output not working
Unread postby indyhog » Sun Jul 23, 2017 8:59 am
So in a previous post upgraded my fox to a Mark 8 ecu and got it running fine, drove it about two miles. Next upgrade was electric fan and 3g alt, which was setting around for years and parts store checked it out as good. I got every thing wired up correct per the website using pin 32 etc. In BE I enabled the fan, and even tried several temp to turn on but no fan. The wiring is good as I can jump the pin 32 to ground and the fan kicks on problem. Is there something else I need to do?
indyhog
Name: Gregory Hogge II
Vehicle Information: 1990 Mustang GT
A9L2+BE+EA+MOATES
393W @10.3:1
FMS J302 HEADS/Z303 CAM/Super Victor Intake/90mm TB
38# Lucas Injectors/stock slot MAF
Tr3550/mac exhaust
Tipp City, Ohio
Vehicle 2 Information: 1995 f250 powerstoke
Re: HSF output not working
Unread postby decipha » Sun Jul 23, 2017 12:30 pm
high speed is usually a positive output, check that first
depending on the year, i thought mark 8s had variable speed fans? if so its a pwm output and youd need the fan controller, thats true for the 98s IIRC
if you feel up to it you can reprogram one of the unused pins for an on/off fan if you want
Unread postby indyhog » Sun Jul 30, 2017 8:08 pm
Finally had a chance look at this again. seems to be working now wired like you show in your site. Not sure what I did, I had just been playing around with different temps and enabled low speed fan.
indyhog
A9L2+BE+EA+MOATES
393W @10.3:1
Tr3550/mac exhaust
Tipp City, Ohio
Unread postby decipha » Sun Jul 30, 2017 9:01 pm
what ecu do u have?
Unread postby indyhog » Mon Jul 31, 2017 8:44 pm
Code is z4h0 out of a mark 8. 94 or 95. I forgot which year
indyhog
A9L2+BE+EA+MOATES
393W @10.3:1
Tr3550/mac exhaust
Tipp City, Ohio
Unread postby decipha » Tue Aug 01, 2017 11:59 am
indyhog wrote:...and enabled low speed fan.
thata the ticket right there, its actually not the low speed on/off swith, its the fan present switch, if EDF is disabled it bypasses the high speed fan lookup routine
Unread postby indyhog » Wed Aug 02, 2017 7:55 pm
Glad that was it. could you add that to you electric fan write up? It may save someone from posting that question again.
Thanks!
indyhog
A9L2+BE+EA+MOATES
393W @10.3:1
Tr3550/mac exhaust
Tipp City, Ohio
Return to EEC-IV Tuning
