data error on universal adx
Unread postby Bad86capri » Sat Jun 03, 2017 5:57 pm
ive downloaded the universal adx and opened it. ive searched for patch and couldnt find it. im getting a data error when trying to log and dash looks jumbled up.
Bad86capri
Vehicle Information: 86 Capri T-Top. Oxford white, grey trim and canyon red interior. 306 with twisted wedge heads, Anderson b3 cam, holley systemax intake, ev6 30lbs inj., c&l 80mm maf, 70mm tb, longtube headers. Im currently using a plx wideband mounted in the driverside header. Tuning with moates quarterhorse and BE although sometimes i play around with Tunerpro
Re: data error on universal adx
Unread postby decipha » Sat Jun 03, 2017 6:40 pm
thats cuz i hadnt posted it for gufx
Unread postby Bad86capri » Sat Jun 03, 2017 8:35 pm
Oh. What do I need to do to datalog? I'm having a issue right now with it going lean at wot and I can't figure it out because I can't datalog.
Bad86capri
Unread postby decipha » Sat Jun 03, 2017 9:24 pm
on the homepage theres a link to the gufb adx
Unread postby Bad86capri » Sun Jun 04, 2017 8:25 am
Ok. Thanks!! I'll get it up and running today
Bad86capri
Unread postby Bad86capri » Sun Jun 04, 2017 6:03 pm
im getting a invalid file error when i try extract the files
Bad86capri
Unread postby decipha » Sun Jun 04, 2017 6:12 pm
ah yea thats from the sever move
ill post an updated eec-iv logging file tonight
Unread postby Bad86capri » Sun Jun 04, 2017 6:18 pm
ok ill be looking for it. thanks again! i think im going to try the ecu controlled fan when i get car straightened out.
Bad86capri
Unread postby Bad86capri » Mon Jun 05, 2017 7:11 am
Did you have a chance to get the adx file fixed?
Bad86capri
Unread postby decipha » Mon Jun 05, 2017 3:50 pm
i didn't get a chance to even get to my laptop last night
here's the gufb adx, load this in and lmk if it works
DO NOT ENABLE THE UNVERSAL ADX in the tune, this old adx has the patch code in it for the antiquated logging code
Unread postby Bad86capri » Mon Jun 05, 2017 4:39 pm
Thanks!
Bad86capri
Unread postby decipha » Mon Jun 05, 2017 10:15 pm
did it work?
Unread postby Bad86capri » Tue Jun 06, 2017 12:27 pm
By the time I seen your reply it was too late to try it. I'll try it when I get from work today
Bad86capri
Unread postby Bad86capri » Tue Jun 06, 2017 3:06 pm
it works. thanks again
Bad86capri
Unread postby 89mustangcoupe » Mon Jun 19, 2017 12:42 pm
thanks was looking for this
89mustangcoupe
Vehicle Information: 1989 ford mustang lx coupe a9l ecu, moates quarter horse, plx dm6 wideband,tuner pro rt, 302 stock block,9:9:1 CR sealed power forged pistons, eagle I beams, eagle crank, gt40p heads with mild porting on exhaust, crane conical valve springs ,1.7 crane cams cobra rockers, Anderson n-21 cam, Vortech V1 S-trim, FMIC, Siemens Deka 60lb injectors, pro products AFPR, PMAS HPX-E Blow thru MAF, typhoon professional products intake with 1 inch spacer, bbk 75mm tb with egr delete,msd blaster coil,accel distributor module, Mallory hyfire 685, T5 trans, strange 35 spline axles and full spool with 4:10 gears, FMS shorty headers bbk x pipe, flow masters to tail pipes, Autolite 103's
Vehicle 2 Information: 89 Camaro RS 305 TBI Auto Stock
Return to Foxbody Tuning
Users browsing this forum: No registered users and 44 guests
