EEC-V Master Hardware List
Unread postby decipha » Sat Apr 02, 2016 7:31 am
Below is a hardware list of hardware codes and strategies, this is extremely useful for knowing what you can use on which ecu hardware
here is a link to check the most up to date ford calibration for a given catch code, also shows the hardware code as well
http://www.obdtester.com/ford-ecu-update/
http://www.obdtester.com/ford-ecu-info/
why is this important? well disassembly is no easy process and that in itself is pretty time consuming then writing a def file and keeping up with datalogging etc... can be a bit tedious, this list will show which hardware codes are support by which strategies therefore its absolutely useless to disassemble more then one strategy within the same group since they are the same, hopefully this will help out the DIY community so we can focus on supporting a vast majority of the hardware and not have to focus on specific strategies.
I've compiled this list myself over the years tuning different setups so most of the info here is correct but if you find anything that isn't please note it so it can be corrected.
96-97 Mustang (2 bank)
CDAN4 codes
ML2-304 (v6)
ML2-334
ML2-335
ML2-309 (v6)
covers CDANA, CDAN3
98 mustang - 4 BANK
CRAJ0 Codes
ML2-872 (v8)
ML2-891 (v6)
possibly below is 4 bank
covers CRAI8, CRAI5,
should support ML2-871
works with CRAIA, CRAIB, CRAIC, CRAI9
MLC-411, MLC-441, CXAB1, CXAB2, CXAB3
99-01 mustang
CVAF1 codes
MLC-461
MLC-462
covers CVAE7, CVAE6, RVAD0, RVAF1, RVAF2, RVAF3,
Late 01 Mustang, kind of a bastard, FBGI0 will run it fine UNTIL it throws codes. CVAF1 will throw bad coil codes.
RVAFA, RVAFB
MLC-463 ??
MNAE0 codes - 99 & 00 Lightning
MLC-482
MLC-481 - POSSIBLY MLC-481A
MLC-491
does not work for MLC-482A (04-L) as the pin mapping required recoding
covers MRAD3, MRAC0, MRAD2, MBAI3, MBAI5, MBAI7, MBAI9, MBAIB, MBAJ2,
MBAJ3, RDAB8, RDABB, RDABC, RDABD, RCAB0 ?
MLC-482A - 04 Lightning TAUF0 / URB1 - independent strategy
02-03 Mustang V8 - Can be replaced with FBGI0
MPC-14A
MPC-14B
MPC-14D
MPC-14E
MPC-14F
MPC-14G
covers RYAC2, RYAE0, RYAF0, RYAF1, RYAK0, RYAK1
03-04 cobra
FBGI0 codes
MPC-14C
covers RYBD0, RYBE0, RYBE1, RYBE2, FBFG2
FBGH0 too?
99-03 5.4L w/ 4R100 E-SERIES, F-SERIES, EXCURSION, EXPEDITION, NAVIGATOR
MZAK0 codes
MLC-496, MLC-496A, MLC-497, MLC-421, MLC-422, MTC-321, MTC-322, MTC-323
MTC-331, MTC-421, MTC-421A, MTC-422, MTC-423, MTC-431, MTC-301, MTC-302
Covers
MMAC0, MMAD0, MMAF1, MMAH0, MMBB0, MPAJ0, MPAK0, MPAL1, MPAL3, MPAL4
MPAL5, MPAL6, MPLAB, MPALC, MZAD1, MZAE0, MZAG0, MZAG1, MZAH0, OIAE1, OIAG0,
OIAH0, RFAH1, RFAH5, RFAH6, RHAG1, RHAG6, RHAG7, RHAG8, RHAGB, RIAE0, RIAH0, RIAI0, RIAI2
MMAGA, MPAM0, MPAM1, MPAMA, MZAD2, MAAG2, MAAG4, MZAK0
02 LINCOLN NAVIGATOR / BLACKWOOD & 01 F-150 - 4R100
MQAH1 codes (can run FBGI0 w/ manual or 4R70W)
MPC-141
covers (4r70w and 4r100 mixed)
MQAI0, MQAF0, MQBH1, MQAI1, RWAF0, RWAI0, RWAI1, MQAH1 (4r100), RWAI2 (4r70w)
95 RANGER
AJAP2 codes
ML2-202, ML2-101, ML2-102, ML2-201
covers AJAP3, AJAP4, AJAP5,
96 RANGER
AJAQ5 codes
ML2-112, ML2-111, ML2-211, ML2-212
covers AJAQ4, AJAQ3, AJAQ5
Note: Uses dual coil packs with offset staggered ignition
2001 - 2003 Ranger / Explorer / Mazda B-Series 3.0L & 4.0L
MP2-111, MP2-112, MP2-113, MP2-114
covers
peav1, peav6, peaw7, pyaec, pyaed, pyaf1, pybd2, pybb0, pybd3, pycl7
pybd0, pyaf5, pyaf2, pyae1, pyaea, pyad0, pyac0, peav2, peav4, peaw0
peaw1, peaw2, peav3, peav8, peav9, peap1, peas0
2006 Ranger 2.3L EEC-V (last year)
MP2-25B hardware code
Cal Code XNV0 - Manual Trans
PRDO0 Strategy
appears to be an independent strategy
Note: uses only 1 coil pack with no anti theft
01-03 LIGHTNING & 02-03 HARLEY
OMAE2 codes - note OMAE2 is missing the 4.0 clock index table, can be added in
MPC-206
covers OMAE1, OMAD4, OMAD3, OMAD2, OMAD0, OMAC0,
MAYBE MPC-205 & 204 - ODAL1, ODAI0
2002 F-150 4.6L 4x4
ODAJ0 codes
MPC-201, MPC-207, MPC-202
covers
OCAF0, OCAH0, OCAJA, OCAL0, OCAM0, OCCB0, ODAG0, OCAJ0
03-04 Crown Vic / Grand Marquis / Marauder
RZASA codes
MPC-175, MPC-176, MPC-177, MPC-178, MPC-185, MPC-186,
MPC-187, MPC-188, MPC-195, MPC-196,MPC-197, MPC-198,
covers
RZAO0, RZAO1, RZAO2, RZAM0, RZAN0, RZAR1, RZAS0, RZASA
RZAU1, RZAU0
note: although these ecus can run the FBxxx tunes, these ecus physically do not
have fan outputs nor a starter interrupt output if not used factory equipped in the ecu.
03 Crown vic / Town Car / Grand Marquis
RZAJ0 codes
MPC-155, MPC-156, MPC-157
Note: same notes apply as rzasa, can prob run RZASA
1996-1997.5 Explorer & Mountaineer 5L
CQAB3 codes - (2 bank)
ML2-4D1, ML2-336
covers
CQAB0, CQAB1, CQAB2, CQAB3, CTBAE, CTBAF, CTAAA, CTAAD,
98 E-Series / EXPLORER/ MOUNTAINEER - (4 bank)
CJAB1 codes
ML2-451, ML2-431, ML2-432, ML2-473
covers
CPAI1, CJAB0, CPAF3, CPAGB, CPAIA, CPAIB, CPAF4
CPAI3, RAAD3, RAAD4, RAAD0,
97 F-150
CTAA8 codes (2 bank)
ML2-331, ML2-332, ML2-352, ML2-353
covers
CTAA5, CTAA1, CTAA7, CTAA8, CTAA6
can possibly run a cdan4 tune if configured properly
00 EXPLORER
REAC3
REAC4 - ML2-8A1
READ0 - ML2-8A1
Note: appears strat is for EQE3 tune only
Re: EEC-V Master Hardware List
Unread postby jhine5588 » Thu Mar 09, 2017 6:26 pm
What could you tell me about these EEC's? Are there def files out there for them?
Jeremy
jhine5588
Vehicle Information: 1983 LTD station wagon: Blueprint 5.0 longblock, TFS springs and intake, B-cam +4 degrees, MAC longtubes, catted H-pipe, Deka 80's, C&L 76mm 230whp/280ftlbs
Unread postby decipha » Thu Mar 09, 2017 6:44 pm
haha I recognize that ecu, those oddball ones are from a mazda 626
yep ALL ecu's are reprogrammable, it just depends on if you want to spend on the money on creating support for it or not
there is none out there, and the mazda code is quite different from henrys so that would be pretty costly to develop, your looking 1,000 minimum to have an xdf file written for it
Unread postby jhine5588 » Thu Mar 09, 2017 7:01 pm
I was afraid that was going to be the answer... It will likely come to fruition. It will be a grand worth spending in my eyes to have the car running properly and maintain NYS OBD compliance.
Jeremy
jhine5588
Unread postby kwikamc » Sat Mar 11, 2017 9:44 pm
Ok, I am a newbie to the forum and this type of tuning. I have transplanted a motor and trans from a '98 Crown Vic cop car into an old truck. It runs fine. However, I am in the process of building a 5.4 PI engine, along with a set of aftermarket cams. What changes, if any do I need to make to the PCM to allow the new combo to work with that PCM? How are changes made? Do I need to purchase other components to make this happen?
Thanks in advance, Steve.
kwikamc
User
Vehicle Information: 1956 F100, stock '98 Crown Vic motor, trans, and controller.
Vehicle 2 Information: 1971 AMC Matador, still carbureted, but fast!
Unread postby decipha » Sun Mar 12, 2017 1:04 am
hey steve welcome to the forum
im not sure if the 98 vic had pats on it or not i cant recall off the top of my head, I want to say it doesnt iirc, its been a long time since ive played with one
in any case, you dont HAVE to change anything if you dont want to, as long as your using the same maf and injectors itll run perfectly fine
always best to properly dial it in though
software wise at that time i think its gong to be either CRAIA or CRAIB was the strat being used on them depending if its early or late year, its very similar to CRAJ0 which Ive actually ran on them before many moons ago
that strategy has been on the to do list for some time theres an xdf floating around thats complete but not very well put together, best bet would be to go the remote tune route which then forces me to clean the xdf up
Unread postby kwikamc » Sun Mar 12, 2017 7:10 pm
Thanks for the answers. This PCM doesn't have PATS. Police and taxi were built without PATS for obvious reasons, so it was easy to "plug and play". I was just unsure if the stocker could be improved.
kwikamc
User
Unread postby TerranceR » Fri May 19, 2017 1:54 am
jhine5588 wrote:I was afraid that was going to be the answer... It will likely come to fruition. It will be a grand worth spending on venapro in my eyes to have the car running properly and maintain NYS OBD compliance.
Jeremy
Feel free to share the file when it's done. :D
TerranceR
User
Vehicle Information: 2016 Audi RS5
Unread postby 94LSVT » Tue Aug 15, 2017 1:59 pm
i realize this list is for EEC-V but i was wondering if any other box codes will run CBAZA?
94LSVT
Vehicle Information: 91' Mustang 5.0 LX
A9L2 w/ Quarterhourse & BE
347 stroker w/ TFS 190s & R manifold
Comp Cams XE282HR
79' Mustang
351w w/AFR 185s & GT40 intake
CBAZA
Unread postby decipha » Tue Aug 15, 2017 7:08 pm
the A4A1 iirc its the same hardware code from a 94 crown vic or town car cant remember
Unread postby Pappacosworth » Tue Mar 27, 2018 6:53 am
V6 ecu, boc code LWC3, xdf for it CDAN4_170818b.zip? how to datalog?
Pappacosworth
Fabricator
Vehicle Information: Ford Mustang Cobra -94 Mach swap in progress
Vehicle 2 Information: BMW F650GS with Power Commander
Unread postby decipha » Tue Mar 27, 2018 11:26 am
you cant i never wrote it or didn't release it
Unread postby Pappacosworth » Tue Mar 27, 2018 11:57 am
Binary Editor only change?
Pappacosworth
Fabricator
Unread postby decipha » Tue Mar 27, 2018 12:01 pm
thats your best bet, be sure to get the complete cdan4 def from sailorbob for BE
Unread postby rubyatiy » Thu Jan 10, 2019 7:12 am
TerranceR wrote:
jhine5588 wrote:I was afraid that was going to be the answer... It will likely come to fruition. It will be a grand worth spending on PhenQ in my eyes to have the car running properly and maintain NYS OBD compliance.
Jeremy
How you are terminated with those free feel share ? Oooppsss
rubyatiy
User
Vehicle Information: 2008, Mazda, Petrol, 600cc, HID, Foog Light, 4 seater, abs, air bags, 2 wheel drive
Unread postby decipha » Thu Jan 10, 2019 1:15 pm
I do not know of any mazda defs
Return to EEC-V & SN95 Tuning
