"Security" tune
"Security" tune
Unread postby RIKIL » Sun Jan 01, 2017 5:28 pm
I want to have a tune I can load that will start the vehicle but not allow the RPM to go above 1500. I'd rather not disable starting completely, I think it is best to make the vehicle immobile.
RIKIL
++Premium Elite Member
Vehicle Information: Red, 1992 F150, 351W, 4R70W, Vortech V-2 Si trim blower, Snow Performance water/meth injection system, custom cam, Edelbrock Performer intake, Twisted Wedge 205cc heads, shorty full-length headers, MASS Air (converted), tuning with CBAZA / QuarterhorseRT, 4x4, short bed, 33" tires
Re: "Security" tune
Unread postby SlowBox » Sun Jan 01, 2017 6:01 pm
Set the rev limiter to 1500.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: "Security" tune
Unread postby RIKIL » Sun Jan 01, 2017 6:08 pm
What is the rev limiter called because I looked and didn't see anything obvious. I'm using a U4P0
RIKIL
Re: "Security" tune
Unread postby decipha » Sun Jan 01, 2017 8:17 pm
are you using the latest cbaza def off the homepage?
Its under the rpm / limiters menu
Re: "Security" tune
Unread postby RIKIL » Mon Jan 02, 2017 12:14 am
decipha wrote:are you using the latest cbaza def off the homepage?
I was not using the latest def or the latest tuner pro. I have installed both and see a lot of new items from adding the new def. I will look closer tomorrow when I have more time. I need to read up about patches in Tuner Pro, I had not seen that before and when I searched for 'rev', one of the results that came up was something about a patch. thx
RIKIL
Re: "Security" tune
Unread postby RIKIL » Mon Jan 02, 2017 10:03 am
is this latest def meant to be encrypted? Makes it hard for me to read the description of the parameter, that's all.
RIKIL
Re: "Security" tune
Unread postby decipha » Mon Jan 02, 2017 10:25 am
no tunerpro doesnt have any of that encryption crap
press the f10 key to bring up the comments box
Re: "Security" tune
Unread postby RIKIL » Mon Jan 02, 2017 10:41 am
great, I will use that window...but it is still blank. I switched back to my previous def and I can get the info to show in the parameter window. This is what I downloaded - http://efidynotuning.com/xdf/CBAZA_20161212.zip
When I open that file in an editor, it is not text like other defs, and this new one is not readable in an editor so I assume it is encrypted
RIKIL
Re: "Security" tune
Unread postby decipha » Mon Jan 02, 2017 10:45 am
did you unzip it to get the xdf ?
Re: "Security" tune
Unread postby RIKIL » Mon Jan 02, 2017 10:57 am
yeah, the new XDF is loading correctly, I verified by looking at Engine Displacement, was the same as the previous XDF
RIKIL
Re: "Security" tune
Unread postby decipha » Mon Jan 02, 2017 11:24 am
I don't think I understand what your trying to do?
Re: "Security" tune
Unread postby RIKIL » Mon Jan 02, 2017 5:45 pm
Sorry, I am not trying to be a pain. All I really want to do is set a rev limiter in my tune, since it isn't called something like 'rev limiter', I need to search through the details for each parameter to find the rev limiter. I can't see the details in the new def that I loaded, but the def does load fine in TunerPro
RIKIL
Re: "Security" tune
Unread postby RIKIL » Mon Jan 02, 2017 5:54 pm
The comments are showing up now. I had to use F10 to open the window then the close and reload TunerPro
RIKIL
Re: "Security" tune
Unread postby RIKIL » Mon Jan 02, 2017 6:16 pm
I got what I needed, I set NLMTHI and NLMTNEUHI to my max RPM, this will limit the RPM in both neutral and drive gears
RIKIL
Return to EEC-IV Tuning
Users browsing this forum: Google [Bot] and 2 guests
