RAAD3 Tuning
masnecar
Vehicle Information: 1998 Ford ranger
ENGINE / ELECTRICAL SWAP -
1998 Ford Explorer 5.0 PCM / BCM / ENGINE / ALL WIRING
Engine Mods:
1995 Mustang 5.0 Bottom end
GT40P heads milled .010
1.7:1 Rollers w/ Cobra hyd roller lifters
Comp Cams XE264HR
.010 oversize exhaust valves
beehive springs
Stock intake/exhaust (for now)
24lb injectors, 255lph pump, ready for install, TM Headers on order
RAAD3 Tuning
Unread post by masnecar »
I am getting ready to get my truck tuned after having built and swapped a 5.0 into my Ranger, and am preparing to order the quarterhorse to get it tuned. I have not been able to confirm yet if my ECU is supported or not. Details from my ECU are below.
PCM - Powertrain Control Module
Part number: F87FAVB
Strategy : RAAD3G5
Hardware type: ML2-473
Copyright Ford Motor Co. 1997
Is this PCM supported? I searched and was unable to find anything in particular pertaining to this specific ECU.
masnecar
Engine Mods:
Comp Cams XE264HR
beehive springs
Re: RAAD3 Tuning
Update: I reached out to Moates, and they said the quarterhorse is NOT supported for my ECM - however they referred me to Core Tuning.
Upon looking at their website, it appears they are trying to sell a package with Binary Editor and QuarterHorse - this does not make any sense.
Help?
Re: RAAD3 Tuning
all ecus are supported but you have to become a premium member
masnecar
Engine Mods:
Comp Cams XE264HR
beehive springs
Re: RAAD3 Tuning
decipha wrote: 2021 Jun 28, 21:13 all ecus are supported but you have to become a premium member
Awesome - Will do. Question though, do I purchase the hardware (quarterhose) through you, or through Moates directly?
Re: RAAD3 Tuning
moates directly but they are backordered til august
masnecar
Engine Mods:
Comp Cams XE264HR
beehive springs
Re: RAAD3 Tuning
Quarterhorse has arrived! Is there any additional hardware I will need to purchase before becoming a premium member and getting the tune started? Wideband, etc? I'm not looking for gains initially (planning on running a base/stock tune for now), just datalogging, maybe increase rev limiter and change shift points.
Re: RAAD3 Tuning
Nope
We can do the tune now but the logging is gonna take me a couple weeks to create.
