[J1X] 4.9L Stock Tune/Strategy
Post by efloth »
I posted this over at the https://fordsix.com/threads/stock-ecu-tuning.82060/ today. Useful for anyone with a 4.9 and manual trans or for adapting A1C for the 4.9l and auto trans
SD40A-J1X-4.9L-04142021.zip
(296.6 KiB) Downloaded 1478 times
Re: 4.9L Stock Tune
Post by efloth »
Ported Decipha's patch for extended VE table
SD40A-J1X-4.9L-06092021.adx
(301.96 KiB) Downloaded 1462 times
SD40A_J1X_4.9L_05252021.xdf
(246.48 KiB) Downloaded 1447 times
Re: 4.9L Stock Tune
Post by efloth »
Updated ADX, still a few broken items
DECIPHA_210620_J1X.adx
(384.64 KiB) Downloaded 1557 times
Re: [J1X] 4.9L Stock Tune/Strategy
Post by decipha »
fn703f different y axis equation /128 (iirc) and only 10 points as well
fofaster
Vehicle Information: 1995 Ford F-150 4.9L 'Big Six' M5OD-R2
J1X Ethanol FREE 87 w/ stock EFI emissions delete/detune
Post by fofaster »
Been working with efloth over on fordsix forums, I wanted to bring this over here and post the latest updates to this strategy. My motor setup has all the emissions removed, if you are using this and have emissions equipment installed you probably need to re-enable those flags. Still working on a completely dialed in VE Table but this should be a good place to start for anyone that wants to use this strategy. You probably need to turn down the A/C fan load in this, I keep forgetting tbh.
I am green tuner and my strategy could harm your vehicle unintentionally. DO NOT INSTALL FOR DAILY DRIVING (still developing this into a more stable tune with a truck that I can afford to blowup) you do download this and make it better PLEASE repost your strategy
UPDATED 6/22/2024 Fuel is a lot more dialed in and this strategy seems to be running A LOT smoother than before. If you've downloaded this before, you might consider redownloading this update. Still working on start up idle, might need to retune the idle air again. This is again for a stock motor with emissions deleted, 3* of spark added across the board, extended VE. Make sure your timing is set mechanically to 10*
J1X_emissions_strategy.zip
(309.6 KiB) Downloaded 1000 times
73Torino351C2V
Vehicle Information: 1990 E150
Ported head
Larger valves
Custom cam
4.9 inline 6
Post by 73Torino351C2V »
I have an e4od. Where is the correct down load for efi-sd47a?
GeneratorGene
Vehicle Information: 95 f-150 XL, 4x4,single/short, manual trans, 4.9 I6 EEC-IV SD40A, EGR/air pump delete, flowmaster
Many more mods to come.
Post by GeneratorGene »
Still happy with this tune? Looks like exactly what I need to get started with my build, thanks!
