Linking Wideband O2 sensor to A9L ECM
zcodeboyz
Vehicle Information: 1988 Mustang LX
Unread post by zcodeboyz »
I have an Innovate MTX-L wideband O2 sensor That I'm trying to get linked up to my A9L ECM using Tuner Pro RT and a Moates Quarterhorse. I'm trying to use the Pin #27 voltage input method. The gauge is outputting 2.75 to 2.78 volts at 1.00 to 1.02 lambda at the old EGR voltage input circuit. I have continuity all the way to The ECM at The pin 27 location. I cannot get the Tuner Pro RT ADX file to recognize the signal. The settings on the General and Conversion tabs appears to be correct. The 8 other values on my dashboard are all active and working. Any help on getting this issue resolved?
zcodeboyz
Re: Linking Wideband O2 sensor to A9L ECM
Between my two AI Bud's, CGPT and Super Grok, We figured it out. Issue resolved.
There is no setup its all automatically done.
If its not logging then a wire was not making a connection.
