Swapping from e4od to c6 transmission. What values should I use on the scalars to disable transmission for the eec? I know tstrat should be 0. What value does trload need to be set to? Are there any other scalars that need to be modified?
Thanks for the help
Disable transmission.
s74p13s
- Vehicle Information: 1984 EFI Swap Ford Bronco U2L1 EFI-SD48B.5.8 lightning clone engine. GT40 Heads,Edelbrock Intake,Exhaust,Comp Cams 35-255-5
Re: Disable transmission.
0 as well
theres a 6 cyl and an 8 cyl manual file, you can download either and compare as well
youll want to nullify the tot to 100 deg F and dial in dashpot
s74p13s
Sounds good, thanks for the info decipha!
