It looks like you lost all of the archives.
I'd like to resurrect the topic of using a closed pcv system with boost. I had our discussion bookmarked because I have the memory of an earthworm.
In your pre tune info; you say this:
"The PCV system MUST be completely sealed. For boosted engines, a check valve is required to be installed between the valve cover breather and the inlet/suction side of the turbo/supercharger. The check valve must be mounted in reverse so under non-boosted conditions, the PCV will evacuate the crankcase and suck the check valve shut. Use only PCV valves that have internal checks and will lock to prevent backflow or bleeding of boost pressure into the crankcase. With this configuration, during boosted conditions, the manifold reference PCV valve will lock and the check valve on the breather line will open from the inlet vacuum to evacuate the crankcase. For race engines, it will be necessary to install a catch can to prevent oil from entering the intake. For more details see THIS THREAD."
I believe the thread linked at the end was the discussion I started previously about this topic. Hopefully this link can be restored for all users after we discuss this again.
In your above scenario; wouldn't there need to be a check valve in the hose between the upper intake and pcv? The check valve would be inserted backwards so the direction of flow is from the pcv back to the upper intake to prevent boost from entering the crankcase. In my case; I'd like to use a separator between the upper intake and pcv as well.
Also; would an oil catch device be needed in the hose leading from the oil fill nipple to pre turbo fitting?
Could the pre turbo fitting actually be located into the intake tubing as another alternative?
Thanks!
Eric
