crai8 loads dropped 24%
redtopracer
Unread post by redtopracer »
Like the title says, load dropped almost 25% across the board with the new bin. Previous peak was 94% now its 70 and im not sure why lol.
Maf still shows same peak flow, so i doubt im loosing a cylinder.
deciphabinunscaled4.23.bin
(256 KiB) Downloaded 692 times
Re: crai8 loads dropped 24%
your old tune scaling was off
if you reduce the engine size then load will come up
redtopracer
Well don't I feel extra special now lol. Thanks
redtopracer
Not having any issues other than the same I was with the scaling for the SP* that I was with craj0 bin. What am I doing wrong in following your instructions on them? The scalar still throws the whole thing off, and if i change the scalar to 1 it of course moves the fuel settings. changing the fuel settings results the scalar doing its auto thing again.
why are you changing them ??? do they not already have accurate values ??
redtopracer
None of its done like you say it should be. Is there a benefit to having the global k constant to 30 and all that?
edit,fuels scaled correctly, wideband reads same as commanded. but global k constant isnt done like you say. to clarify
