EESucka - found on ebay
Look what I bought, currently in my possession:
Re: EESucka - found on ebay
Thats pretty archaic. The quarterhorse does it much cleaner.
dnschneid
- Vehicle Information: 1995 Ford F150 XLT 4x4 5L manual M5OD-R2 (might upgrade to ZF5 later), 3.55 diffs, 30" tires (31.7" planned), e-fan (separate temp sensor, Flexalite 295)
EFI-SD42F / JOY0
Tuning a 347 w/ RV cam, 1.7 rollers, 60lb deka injectors, but otherwise stock (in particular the stock 30-45lb FPR). Emissions vehicle.
WB_AEM-X
Wire wrap *and* solder? That's high-end prototyping there ;)
This is the original, came with a binder of notes.
Any info in the notes over and above the github link above?
The notes include the original schematics, same as scanned in links above, other than a couple sticky notes.
Also has a print out of original MS .bas code.
I got it just for the fact it’s old, cool and geeky fun.
Turbo Tbird
- Vehicle Information: 1993 Ford Thunderbird SC
3.8L V6
8.8:1 compression
polished SC crank
Ross custom pistons
Eagle rods
dual valve springs
Precision 46mm waste gate
3" exhaust w/ cutout
FMIC
SCT BA5000 MAF
Tial Q 50mm BOV
80lb Siemens Deka injectors
modified F-150 4.2 fuel rail
Walbro 450 HP pump
8AN feed, 6AN return
wbo2_lc1mtxl
i think it's really cool. i assume this was something from the very early days of EEC IV tuning, like early-mid 90s?
I still think doing a UV erase / in place reprogram of the factory eprom would be the most useful development. I love the quarterhorse but being able to reprogram the box when done tuning would be amazing. Any hope of using something like this to reprogram it? I have a ECU with a bad injector driver I'd be willing to donate for testing purposes.
Yeah, I’m still thinking the same, but my research showed max uv erase/reprogram on these chips will only happen 50 to max 100 times then they fail completey
