EEC V file conversion
Re: EEC V file conversion
There was a mention of word alignment in the indirect address mode section, I just do not remember, and can not find where it says how it is accomplished, I guess the fill is skipping a spot to properly align the address?
8f91e: c7,e0,9a,13 stb R13,[Re0+9a] [1111a] = IO_Timer_Hi;
8f922: a1,52,f9,36 ldw R36,f952 R36 = f952;
8f926: a1,64,0f,38 ldw R38,f64 R38 = f64;-
8f92a: b1,04,46 ldb R46,4 R46 = 4;
8f92d: a1,ed,cb,3a ldw R3a,cbed R3a = cbed;
8f931: f2 pushp push(PSW);
8f932: fa di interrupts OFF;
8f933: 20,03 sjmp 8f938 goto 8f938;
8f935: c2,39,34 stw R34,[R38++] [R38++] = R34;
8f938: 10,08 rombk 8
8f93a: a2,37,34 ldw R34,[R36++] R34 = [R36++];
8f93d: c7,01,62,0f,3a stb R3a,[R0+f62] [10f62] = R3a;
8f942: c7,01,6e,0f,3b stb R3b,[R0+f6e] [10f6e] = R3b;
8f947: e0,46,eb djnz R46,8f935 R46--;
if (R46 != 0) goto 8f935;
8f94a: c7,01,6c,0f,34 stb R34,[R0+f6c] [10f6c] = R34;
8f94f: f3 popp PSW = pop();
8f950: f0 ret return;
8f951: ff ???
8f952: 00,00 word 0
8f954: 00,00 word 0
8f956: 00,00,00 ??? -
Adding in the caller to your post. Another word confirmed at 8F8DA
You have not looked far enough to spot the loop that references another four words up to 8F8DE
Added subsequent code to your post.
You have not looked far enough to spot the loop that references all words up to 8F8E4.
What can be said about SAD?
Do you use the branch (jump) comments I provided with RZASA?
Would automatic SAD produced branch comments help spot the loops in subsequent code in OMAE2?
Added subsequent code to your post.BOOSTEDEVERYTHING wrote: ↑2024 Mar 27, 21:18Code: Select all
Sub_8f976: 8f976: f2 pushp push(PSW); 8f977: a3,ec,34,38 ldw R38,[Rec+34] R38 = [117b4]; 8f97b: ad,04,36 ldzbw R36,4 wR36 = 4; 8f97e: 2f,d9 scall 8f959 Sub_8f959 (); 8f980: f3 popp PSW = pop(); 8f981: f0 ret return; Sub_8f959: 8f959: 10,08 rombk 8 8f95b: 6f,37,d6,f8,38 ml2w R38,[R36+f8d6] lR38 *= [R36+8f8d6]; #<<<<<<<<<< lr38 *= [8F8DA] 8f960: 0d,01,38 shldw R38,1 lR38 <<= 1; 8f963: d3,03 jnc 8f968 if (B15_R3a = 1) { 8f965: bd,ff,3a ldsbw R3a,ff swR3a = ff; } 8f968: c3,37,0a,11,3a stw R3a,[R36+110a] [R36+1110a] = R3a; 8f96d: 09,01,36 shlw R36,1 R36 <<= 1; 8f970: c3,37,42,0f,3a stw R3a,[R36+f42] [R36+10f42] = R3a; 8f975: f0 ret return;
02504: 01,4e clrw R4e R4e = 0; 02506: 10,08 rombk 8 02508: a3,4f,d6,f8,50 ldw R50,[R4e+f8d6] R50 = [R4e+8f8d6]; <<<<<<<<<< 8F8D6..8F8DE 0250d: 05,50 decw R50 R50--; 0250f: db,02 jc 02513 if (R50 < 0) { 02511: 01,50 clrw R50 R50 = 0; } 02513: c2,4d,50 stw R50,[R4c++] [R4c++] = R50; ... 0251e: 75,02,4e ad2b R4e,2 R4e += 2; 02521: 99,10,4e cmpb R4e,10 02524: d3,e0 jnc 02506 if (R4e < 10) goto 02506; <<<<<<<<<
What have we proven?here is where I see 8f8d6 referenced as a word valueCode: Select all
Sub_8f8e6: 8f8e6: a1,40,0f,36 ldw R36,f40 R36 = f40; 8f8ea: a1,d6,f8,34 ldw R34,f8d6 R34 = f8d6; ... 8f90a: 89,e6,f8,34 cmpw R34,f8e6 8f90e: d3,de jnc 8f8ee if (R34 < f8e6) goto 8f8ee; <<<<<<<< 8F8E4 is the last word reference that will be looped.
No mention is made of how IIRC, just that it should be even.BOOSTEDEVERYTHING wrote: ↑2024 Mar 27, 21:33 There was a mention of word alignment in the indirect address mode section, I just do not remember, and can not find where it says how it is accomplished, I guess the fill is skipping a spot to properly align the address?
So yes FF fills the odd address and the word is on an even address.
That 8f8d6 8f8de should be defined with the word command, and just because the words in between aren't directly referenced in the code, they are present so they can be indirectly referenced.What have we proven?
I do have one question about this though, should the word command be used in a range or should I do the addresses individually?
Very user driven. If you do not know exactly how to use it, it will get you completely lost.. LOLWhat can be said about SAD?
I do, but wasn't paying attention to rzasa code when I was looking for the words referenced above.Do you use the branch (jump) comments I provided with RZASA?
Absolutely, that makes it a ton easier to follow the code. I was not going far enough to see the loop, I may have seen it if i was following in RZASA due to the cmt file you provided me. I guess I need to try and make one for OMAE2.Would automatic SAD produced branch comments help spot the loops in subsequent code in OMAE2?
Also, I guess I need to pop over to the other thread and ask if TVRFAN could incorporate the looped scan command and possibly SAD produced branch comments, and loop comments. Also, SAD 5 still doesn't like an address to have both a word value and byte value assigned to it, but it does work in SAD 4.012....mostly.
Indeed, indirect and indexed address modes can reference a series of addresses in a loop.BOOSTEDEVERYTHING wrote: ↑2024 Mar 27, 22:29 That 8f8d6 8f8de should be defined with the word command, and just because the words in between aren't directly referenced in the code, they are present so they can be indirectly referenced.
A range will get the job done quickly, so go with that.
The mantra is user is king, so it will not save you from garbage in garbage out.Very user driven. If you do not know exactly how to use it, it will get you completely lost.. LOLWhat can be said about SAD?
It does not capture the extent of loops, so the user has to be awake to that.
Yeah, not so much as a comparison source for OMAE, just asking if it were useful for RZASA alone.I do, but wasn't paying attention to rzasa code when I was looking for the words referenced above.Do you use the branch (jump) comments I provided with RZASA?
I agree it is so much easier with the jump comments in place.Absolutely, that makes it a ton easier to follow the code. I was not going far enough to see the loop, I may have seen it if i was following in RZASA due to the cmt file you provided me. I guess I need to try and make one for OMAE2.Would automatic SAD produced branch comments help spot the loops in subsequent code in OMAE2?
Generating it line by line is a long and tedious process. I wised up eventually and have a less tedious process, but really messy to do. The DIR and LST are not quite ready for that yet.
One voice requesting this stuff does not carry as much weight as two...or more.Also, I guess I need to pop over to the other thread and ask if TVRFAN could incorporate the looped scan command and possibly SAD produced branch comments, and loop comments. Also, SAD 5 still doesn't like an address to have both a word value and byte value assigned to it, but it does work in SAD 4.012....mostly.
Yes, ask for the scan command to be updated to support range.
Yes, ask for the branch (jump) comments to be generated by SAD.
V4 ignores the duplicate byte and word.
V5 requires a size option for the sym command. I have not tested these yet, I hope they work when I get a chance, as I'd hate to bury TVRfan under more bugs right now.
Yes, Sub command triggers a scan. Both in place will give the duplicate command error.BOOSTEDEVERYTHING wrote: ↑2024 Mar 27, 20:13 I did. I did all of the SCA commands and then went through and found the Subroutines. Should I have gone through and deleted the SCA commands that happened to land on a defined Subroutine?
This includes an updated DIR and the old DIR with changed sort order.
Please use this new one. You can add more to it, such as payloads, scalars, functions, tables and subs. See comments in the file, ask questions if need be.
While table and function commands can have a name, eliminating the need for SYM, my time with V5.08 and Math has convinced me that the FUN & TAB line gets way to long when the name is not on a separate SYM line.
I noticed you liked adding X10 options to convert from hex to decimal. I find it better to use V where possible to convert to engineering units.
Note V1 gives the same answer as X10, something to ponder for better math in V5.08 on.
You will see some Fn & Tb comments as investigate size. I have investigated, check them out, see if it makes sense why I've chosen the size.
Look back at your previous troublesome example, see how it looks now.
I think the stuff I've changed is correct, happy to be proven otherwise.
Yes, Very useful.. I wish I could build them as fast as you can. I still have trouble spotting the loops in the code most times. I also still have issues following along with exactly where the code goes and where exactly it comes back to. But I am getting the hang of it. I wish it would have exact addresses (or line numbers) listed for where to go next so it was easier to go back and forth to follow along.Yeah, not so much as a comparison source for OMAE, just asking if it were useful for RZASA alone.
I will check out the new DIR file today and compare and see how I can improve upon my other DIR file. Do most of the addresses I found for the SYM commands in the old DIR file still hold true, or do I need to start from scratch with those?
Another question I have is, Where exactly are the function names, table names, etc, that everyone uses as standard coming from? Do they come from the eec documents or a specific code that was disassembled in the past?sym 12364 "uuwFn072A_Perload>Row" # Row Scaler
FUN 12364 1237F :UW V32768 :UW V16
My other question is a bit off topic, It says Australia in your bio but doesn't say where? I was wondering what time zone you are in? Just curious I guess.
Also, I have tried adding a sym for table names or subroutines names but it gives me duplicate command errors at times. Is there a certain format to which I need to stick to when doing separate entries for these? And do I keep the SYM with the Func command or in the SYM list?
Thanks again for all the help.
