A1C XDF Additions
A1C XDF Additions
Thanks to wwhite I am adding some parameters to A1C as needed. Setting the Stoich AFR Scalar to 10:1 helped my e85 tune nicely. Please add to your next revision.
Re: A1C XDF Additions
added will be in next update
Thanks for adding the trans stuff. There appears to be an error with FN1355 on the latest XDF. I believe the correct address is A92E but is set at B5DA in the xdf. It wiped fn32s when I set FN1355 to zero so that's how I found it.
correct i fixed it. thanks
FN23T is at B8D6
thanks
when time permits im going to go through all the auto trans stuff and verify
ok thanks, It looks pretty good now but fn23T was just missing
it was labelled wrong on mine.
Fixed hard shifting into third with fn3ulk, I zeroed the 2nd column to force unlock on all 3rd gear upshifts.
I didn't figure out the conversions so any help with that would be awesome.
Func_b73a - FN2LK = Speed ratio delta to relock on upshift to 2nd gear.
Func_b75e - FN2ULK = Speed ratio delta to unlock on usphift to 2nd gear.
Func_b792 - FN3LK = Speed ratio delta to relock on upshift to 3rd gear.
Func_b776 - FN3ULK = Speed ratio delta to unlock on usphift to 3rd gear.
Func_b7ca - FN4LK = Speed ratio delta to relock on upshift to 4th gear.
Func_b7ae - FN4ULK = Speed ratio delta to unlock on usphift to 4th gear.
I added those last month just hadn't posted an update yet.
y axis is delta ratio
b73a and b75e is between 2 functions
fn2ulk is b73e
fn2lk is b75a
after typing that i realize you probably just swapped the e and the a when you typed it.
attached, prob has some other goodies in it to that I added
fn2ulk is b73e
fn2lk is b75a
- A1C_240502.xdf
- (424.18 KiB) Downloaded 803 times
