Telorvek and PTP2
- Vehicle Information: 1949 F1 4.6 4R70W Telorvek MK-97A PTP2
FBGI0 and MGZT
Telorvek and PTP2
I have tried everything I can think of... cranks but won't start, no injector pulse. swapped ecu to a WSX2 with RZASA with the PATS patch applied burned to a Moates chip with no luck. Anyone have experience with this setup?
Re: Telorvek and PTP2
sounds like your either missing the crank sensor input or the injector voltage feed.
What does tunerpro show on the dash while cranking? You should see rpms as its turning over.
FBGI0 and MGZT
I have power at the injectors, didn't check crank rpm with TunerPro but OBDLink with bluetooth adapter shows crank rpm
Then you have some issues.
FBGI0 and MGZT
got it, must have a corrupt burn, reprogrammed again and everything is good
FBGI0 and MGZT
one more thing, i don't see where to change cooling fan on/off temperature setting
FBGI0 and MGZT
also, what would cause the trans to ship super fast? like 1 to 4 in 50yards
check your oss teeth count and make sure your speedo is accurate
FBGI0 and MGZT
ok, oss was 12 changed to 24. found the fan temp settings... one more question, gear ratio settings. factory would have been 3.27, it has a 3.73 now
simple change it
be sure to set the vid speedo switch to 0 so it uses the cal values
