EEC V file conversion
Re: EEC V file conversion
Thank You.
I have a quick question, in EQE3 I have this..
0b57f: 99,03,27           cmpb  R27,3
0b582: d7,26              jne   0b5aa            if (R126 = 0)  {
0b584: 8b,ee,e4,00        cmpw  R0,[Ree+e4]
0b588: d7,08              jne   0b592            if (DS_DLY_TMR = ZERO)  {
0b58a: b1,04,27           ldb   R27,4            TEMP1H = 4;
0b58d: 91,05,28           orb   R28,5            B0_TEMP2L = 1;
                                                 VEGO_RHAVG_N_2 = 1;
0b590: 20,12              sjmp  0b5a4            goto 0b5a4; }
0b592: 32,28,05           jnb   B2,R28,0b59a     if (VEGO_RHAVG_N_2 = 1)  {
0b595: b1,04,27           ldb   R27,4            TEMP1H = 4;
0b598: 20,06              sjmp  0b5a0            goto 0b5a0; }
0b59a: 33,26,0d           jnb   B3,R26,0b5aa     if (STOP_DS_EX = 1)  {
0b59d: b1,00,27           ldb   R27,0            TEMP1H = 0;
0b5a0: c3,ee,e4,00        stw   R0,[Ree+e4]      DS_DLY_TMR = ZERO;
0b5a4: 71,bf,26           an2b  R26,bf           LCL_DS_EGO_OL = 0;
0b5a7: 71,bf,28           an2b  R28,bf           B6_TEMP2L = 0; } }
0b5aa: 99,02,27           cmpb  R27,2
0b5ad: d7,3c              jne   0b5eb            if (TEMP1H = 2)  {
In RZASA I have this...
0b05e: 99,03,27           cmpb  R27,3
0b061: d7,26              jne   0b089            if (TEMP1H = 3)  {
0b063: 8b,ea,e4,00        cmpw  R0,[Rea+e4]
0b067: d7,08              jne   0b071            if (DS_DLY_TMR = ZERO)  {
0b069: b1,04,27           ldb   R27,4            TEMP1H = 4;
0b06c: 91,05,28           orb   R28,5            B0_TEMP2L = 1;
                                                 VEGO_RHAVG_N = 1;
0b06f: 20,12              sjmp  0b083            goto 0b083; }
0b071: 32,28,05           jnb   B2,R28,0b079     if (VEGO_RHAVG_N = 1)  {
0b074: b1,04,27           ldb   R27,4            TEMP1H = 4;
0b077: 20,06              sjmp  0b07f            goto 0b07f; }
0b079: 33,26,0d           jnb   B3,R26,0b089     if (STOP_DS_EX = 1)  {
0b07c: b1,00,27           ldb   R27,0            TEMP1H = 0;
0b07f: c3,ea,e4,00        stw   R0,[Rea+e4]      DS_DLY_TMR = ZERO;
0b083: 71,bf,26           an2b  R26,bf           LCL_DS_EGO_OL = 0;
0b086: 71,bf,28           an2b  R28,bf           B6_TEMP2L = 0; } }
0b089: 99,02,27           cmpb  R27,2
0b08c: d7,3c              jne   0b0ca            if (TEMP1H = 2)  {
So Should the if (R126 = 0) be if (TEMP1H = 3)? If not, could you explain why please? Thank you. Trying to actually learn this stuff as I see things. I do not want to be a bother, but I can not figure out if it a mistake from SAD or if I am missing something.
Just in case you are following with the comparison charts here is an updated version.
Dissasembly Comparison.ods
(39.1 KiB) Downloaded 571 times
Looks like it should be R27 not R126.
TMP1H depends on what you have in DIR.
Which SAD version?
Version 4.012. I have TMP1H in the dir file. It just skips right there. SAD V5.0.2 crashes when I use the dir file with it so I have been continuing on with 4.012.
A bug in 4.012 then.
Yeah, 502 is an alpha build, but some DIR changes may be needed for future builds.
I am having some trouble with this section of my dir file....
SYM  003C "WIP"                       :B0
SYM  003C "WEL"                       :B1
SYM  003C "BL0"                       :B2
SYM  003C "BL1"                       :B3
SYM  003C "TMP5L"		      #UY #??
SYM  003C 02000 0FFFF "TMP5L"
SYM  003C 033DC 03417 "Tb_Addr"
SYM  003c 08743       "BGTMR"
SYM  003C 12000 833DA "TMP5L"
SYM  003C 82345 86789 "WIP"           :B0
SYM  003C 833DC 83417 "Tb_Addr"
SYM  003C 83419 8343A "Tb.CV|"
SYM  003C 8343B 9FFFF "TMP5L"
SYM  003C 92345 96789 "WEL"           :B0
Could you please show me how to correct this and clean it up a bit? I start getting cross eyed when I look at this part! LOL
SYM  003C "WIP"                       :B0
SYM  003C "WEL"                       :B1
SYM  003C "BL0"                       :B2
SYM  003C "BL1"                       :B3
THANK YOU SO MUCH!!!! You make it look easy. LOL. I kept going back and forth trying to clean it up. I am also not getting entries in a bunch of locations for R3C like I had it so hopefully this will help with that as well. The one thing I do not see is the BGTMR entry. It looks like it shows up only on the line I noted in the DIR file. Did I do that part correctly or do I need an end address as well?
Shoot. I am still getting dead spots in the lst file. Do I need to define the areas between the addresses as well, or should SAD pick them up because I have not defined them specifically? Here is an example..
0414c: a3,ff,68,09,3c     ldw   R3c,[Rfe+968]    R3c = [16be2];
04151: 65,1e,00,3c        ad2w  R3c,1e           R3c += 1e;
04155: b3,ff,66,09,36     ldb   R36,[Rfe+966]    TMP2L = [16be0];
0415a: a1,b6,03,3e        ldw   R3e,3b6          TMP6L = 3b6;
Bgtmr, add the end address.
Your bank 0 and 8 for Tb_Addr smells fishy.
Which SAD version/s?
V 4.012
I will double check the Tb_Addr entries again. I may have picked that out wrong for sure. That was much earlier on in the process. I think I have picked up quite a bit since then.
As far as Bgtmr goes, if I only see it in one place do I use the same beginning and end address? I will try and post an example of where i see it and the comparison I found in RZASA that I am going off of.
Here we go.. In RZASA
93015: e0,46,2f           djnz  R46,93047        TMP0L--;
                                                 if (TMP0L != 0) goto 93047;
93018: 56,35,00,40        ad3b  R40,R0,[R34++]   TMP7L = [TMP1L];
9301c: df,77              je    93095            if (TMP7L = 0) goto 93095;
9301e: 56,35,00,46        ad3b  R46,R0,[R34++]   TMP0L = [TMP1L];
93022: df,f4              je    93018            if (TMP0L = 0) goto 93018;
93024: 31,40,06           jnb   B1,R40,9302d     if (WORD_TMR = 1)  {
93027: 07,36              incw  R36              TMP2L++;
93029: 61,fe,ff,36        an2w  R36,fffe         B0_TMP2L = 0; }
9302d: 35,40,08           jnb   B5,R40,93038     if (MILLISECS = 1)  {
93030: 47,01,5a,07,00,2c  ad3w  R2c,R0,[R0+75a]  TEMP4L = BG_TMR;
93036: 20,0d              sjmp  93045            goto 93045; }
93038: 36,40,06           jnb   B6,R40,93041     if (EIGHTHS = 1)  {
9303b: 44,28,00,2c        ad3w  R2c,R0,R28       TEMP4L = TEMP2L;
9303f: 20,04              sjmp  93045            goto 93045; }
In EQE3
08728: e0,46,2d           djnz  R46,08758        TMP0L--;
                                                 if (TMP0L != 0) goto 08758;
0872b: 56,35,00,40        ad3b  R40,R0,[R34++]   TMP7L = [TMP1L];
0872f: df,75              je    087a6            if (TMP7L = 0) goto 087a6;
08731: 56,35,00,46        ad3b  R46,R0,[R34++]   TMP0L = [TMP1L];
08735: df,f4              je    0872b            if (TMP0L = 0) goto 0872b;
08737: 31,40,06           jnb   B1,R40,08740     if (WORD_TMR = 1)  {
0873a: 07,36              incw  R36              TMP2L++;
0873c: 61,fe,ff,36        an2w  R36,fffe         B0_TMP2L = 0; }
08740: 35,40,06           jnb   B5,R40,08749     if (MILLISECS = 1)  {
08743: 44,3c,00,2c        ad3w  R2c,R0,R3c       TEMP4L = R3c;
08747: 20,0d              sjmp  08756            goto 08756; }
08749: 36,40,06           jnb   B6,R40,08752     if (EIGHTHS = 1)  {
0874c: 44,28,00,2c        ad3w  R2c,R0,R28       TEMP4L = TEMP2L;
08750: 20,04              sjmp  08756            goto 08756; }
Of course now that I am looking at it again, maybe I am defining it incorrectly?
