Lopping at idle
- Vehicle Information: 2001 / Ford / F150 / XLT 4.6L 2valve / KHM3
The truck is turbocharged with a Pulsar T51R PSR3584 GEN II Ball Bearing Turbo 0.82A/R Stainless Steel Turbine with a 30.00" X 12.00" air to air intercooler, 80lb Siemens Deka Fuel Injectors, and a Walbro 525 fuel pump, with a blow through slot maf. Transmission is built to handle 600HP and 600 ft lb.
Lopping at idle
Hello everyone I am have a issue with my truck. I can't figure out why it's loping at idle and some times when I come to a stop.
I have changed the idle control settings and IAC duty cycle back to stock with no change. The truck has a brand new motor craft IAC valve.
The truck is turbocharged and tuned with SCT.
PLEASE HELP !!!!
PLEASE HELP !!!!
- Vehicle Information: 2015 Mustang gt Twin turbo
On3 61mm turbos
Id1300x
Mbrp catback
Vp E98
Boostleash/co2
Re: Lopping at idle
Idle airflow tables. Have you dialed them in if it has them?
Re: Lopping at idle
Where are the tables located in SCT and how do I know what to change them too.
Side note I am not new to tuning BUT I still have a lot to learn so if I say something stupid my bad.
I am still trying to figure out what everything is and dose, there is a lot of info on this forum.
Re: Lopping at idle
make sure you have idle transient fuel disabled
under transient fuel >> scalars set No TFC at idle to 1
btw, KHM3 is an ODAJ0 / MPC-201 ecu. http://www.obdtester.com/ford-ecu-updat ... -12A650-KD
Your in the FBGI0 section. All good though.
Re: Lopping at idle
I don't see my section or strategy. Where should I be posting in.
Re: Lopping at idle
Good question. I expected the pcm tuning section but I had specifically wrote in there non ford back in the day. Corrected and moved.
all good
all good
Re: Lopping at idle
Where in my tune can I adjust the idle down table so it is smoother when the truck idles down from a rev.
it is jumpy when the truck idles down.
also I made a small idle adjustment at the throttle blade and the truck would not restart until I put it back in the same spot, what is going on with that.
I am using SCT software .
Re: Lopping at idle
That's dashpot, info is on the homepage.
Sounds like you have some issues going on as that's not feasible.
Re: Lopping at idle
Could the TPS have a bad spot in it, I don't think it is a motorcraft TPS.
but it didn't do it before I uploaded the last tune you sent me.
Re: Lopping at idle
even with the tps unplugged it would still start up
only possibility is that youve closed it too far and it cant get enough air
