Hello, I am looking to get a 04 Lightning they said has a bad PCM (won't stay running)
My question is will a EK01 or EK02 work if I tune it with my QH? I have both of the pcm in my stock.
Thank you
MB
pcm install EK01 EK02 in 04 lightning will it work
Re: pcm install EK01 EK02 in 04 lightning will it work
yep no problem
- Vehicle Information: 2004 ford lightning: built motor, built trans kenne bell 3.2, nitrous
Best 1/8 mile: 5.97 @ 113
1994 ford lightning: 205k stock bottom end lol, tfs 170 heads with baby cam, mid mount vs racing 78/75 turbo, megasquirt tuned.
Best 1/8 mile: 6.53 @ 103
It will work, however it won't run your intercooler pump. I have an 04 lightning and put in the same ECU you listed and there is something different in the pinout where it won't run the pump. I just wired my pump to run fulltime but I'm sure it's easy enough to make it work like factory. Also if you ever want to get rid of one of those ECU's let me know.
- Vehicle Information: 1992 Ford Mustang 5.0 LX vert 5 speed summer edition
347 cid
Long tubs 2.5 full Exhaust
Comp Cams extreme energy 282
Will do Thanks for that useful information. MB
