RZASA adx?
RZASA adx?
Does the RZASA need an ADX file? I don't see it listed in the downloads section.
- Vehicle Information: 69 Bronco w/ 89 Fox 5.0 HO, Explorer: Front Dress, gt40 heads, intake, distributorless ignition w/coil packs, 03 Vic MPC-185 & 01 f150 HD harness, [Quarterhorse, RZASA]
Re: RZASA adx?
<edited>
Standardized adx can be used from any other decipha adx but you have to manually select the strategy your using it on.
Re: RZASA adx?
All of the adx files are the same just the strategy isnt selected if you need to swap strats.
Best to just hold off til I post one with rzasa selected when i get a free moment.
Re: RZASA adx?
Thanks. I started building my truck and will to need to build a base tune to get it started. Got the 21 circuit harness installed this weekend and Ill be starting the engine harness this week.
Re: RZASA adx?
its posted
Re: RZASA adx?
Thanks Mike!
Re: RZASA adx?
Is there a write up for the RZASA minimum changes for needed like there is for CBAZA?
Edit: I think i found it under eec-v strategy swap
Re: RZASA adx?
So I am running into my first problem. the continental data does not have any of the deltaP data that is required for the injector data. Is there a way to calculate the information? The injector data I have is for 43.5psi
Re: RZASA adx?
only way to calculate it is to dial it in. But your not running a returnless fuel system so you don't need it.
