ISCKAM2 updating even with UPDATM set to 255
odrapnew
Vehicle Information: 1989 Mustang 5.0 Coupe.
A9S ECU, Tweecer R/T w/ Binary Editor
TFS Heads, Stg. 1 Cam, Cobra intake, Novi2K blower (on standby for now).
Unread post by odrapnew »
So, I've been playing with manual idle control be keep running into an issue where ISCKAM2 keeps updating, even with UPDATM set to 255.
Looking at my logs, it's about 7 seconds between ISCKAM2 updates.
Any ideas why that's happening?
Anything else I can change to prevent updates?
Re: ISCKAM2 updating even with UPDATM set to 255
From the write up, It seems to me like it will still update the isckam. You double checked the write up and did everything in there?
odrapnew
I believe I set it all up per the writeup, but I'll double check.
And you might be right that it will still update, just take longer.
When I stated it updates every 7 seconds, that's after idling for a decent amount of time....I'm guessing after about 255 seconds. :)
yeah 255 doesn't disable it just makes it take much longer
odrapnew
Got it, thanks.
