03 cobra - SCT Tuning questions
Brewster
347 Cui
AFR 185
Re: 03 cobra - SCT Tuning questions
Unread post by Brewster »
I also am trying to jog my memory but I shouldn't have to return the eec back to stock, just plug in the QH and then the eec uses the QH instead of its own memory ?
yep simply plug it in and read the file off the ecu then write it to the qh. you'll need the fbgi0 adx and xdf loaded in to tunerpro and your good to go.
all the info is in the getting started write up on the homepage
http://www.efidynotuning.com/started.htm#read
Brewster
347 Cui
AFR 185
Best way for me to hook up a wideband to the eec so you can view lambda?
only 1 way same as eec iv
http://www.efidynotuning.com/config.htm
Brewster
347 Cui
AFR 185
Installed the QH, read emulator to tuner pro ? The file is all scrambled, did I miss a step or read incorrectly? I'll post up the current file I yanked if need be.
yeah you failed to read the link and sub section I directly linked 4 posts back.
You have to read the ecu not the QH.
Brewster
347 Cui
AFR 185
Ok so read the chip and now everything is coming up as blank. I can change the Buffer end address from 07fff to 03fff but I cannot add the 4th f which is in the write up. Leaving the auto populated 07fff in the buffer end address hasn't seem to change anything besides it read more bytes. Either way I only get 32768 byte read with it at 07fff and about half that at 03fff. I read through and don't think I've missed anything but I also don't have the option to choose 256k multi bank file.
Brewster
347 Cui
AFR 185
Brewster
347 Cui
AFR 185
EEC-Read-SCT-2.bin
(32 KiB) Downloaded 134 times
Brewster
347 Cui
AFR 185
Oh I forgot to mention as well but should I just give up on the pulling the file out of this thing since its an SCT file that was built around value files ( scaling ) and start fresh for ya ? Or is it best to get this file out of the eec and carry forward with it for now ?
