Data logging patch applied, request code review please.
Do Not Use address: 0xCCE0 for anything, it is the end of list marker with value 0xFFFF.
Data logging patch applied at 0xCD00
Data logging ops list applied at 0xCE00
SUB2 2023-03-22.xdf
(276.89 KiB) Downloaded 372 times
a446: ef,b7,28            call  cd00             cd00 ();
a449: f0                  ret                    return;
cd00: 71,ef,45            an2b  R45,ef           B4_R45 = 0;
cd03: a1,00,ce,32         ldw   R32,ce00         R32 = ce00;
cd07: a2,33,36            ldw   R36,[R32++]      R36 = [R32++];
cd0a: 88,36,00            cmpw  R0,R36
cd0d: df,0a               je    cd19             if (R36 = 0) goto cd19;
cd0f: a2,36,38            ldw   R38,[R36]        R38 = [R36];
cd12: c3,37,00,0d,38      stw   R38,[R36+d00]    [R36+d00] = R38;
cd17: 27,ee               sjmp  cd07             goto cd07;
cd19: 01,30               clrw  R30              R30 = 0;
cd1b: 01,40               clrw  R40              R40 = 0;
cd1d: b1,01,42            ldb   R42,1            R42 = 1;
cd20: a2,33,36            ldw   R36,[R32++]      R36 = [R32++];
cd23: 88,36,00            cmpw  R0,R36
cd26: df,36               je    cd5e             if (R36 = 0) goto cd5e;
cd28: 89,fe,ff,36         cmpw  R36,fffe
cd2c: df,24               je    cd52             if (R36 = fffe) goto cd52;
cd2e: b2,36,38            ldb   R38,[R36]        R38 = [R36];
cd31: a2,33,34            ldw   R34,[R32++]      R34 = [R32++];
cd34: 99,00,30            cmpb  R30,0
cd37: df,0b               je    cd44             if (R30 = 0) goto cd44;
cd39: 98,35,30            cmpb  R30,R35
cd3c: df,06               je    cd44             if (R30 = R35) goto cd44;
cd3e: 69,04,00,32         sb2w  R32,4            R32 -= 4;
cd42: 20,1a               sjmp  cd5e             goto cd5e;
cd44: b0,35,30            ldb   R30,R35          R30 = R35;
cd47: 70,34,38            an2b  R38,R34          R38 &= R34;
cd4a: 98,38,00            cmpb  R0,R38
cd4d: df,05               je    cd54             if (R38 = 0) goto cd54;
cd4f: 90,42,40            orb   R40,R42          R40 |= R42;
cd52: 01,38               clrw  R38              R38 = 0;
cd54: 99,80,42            cmpb  R42,80
cd57: df,05               je    cd5e             if (R42 = 80) goto cd5e;
cd59: 7d,02,42            ml2b  R42,2            wR42 *= 2;
cd5c: 27,c2               sjmp  cd20             goto cd20;
cd5e: 99,00,30            cmpb  R30,0
cd61: df,08               je    cd6b             if (R30 = 0) goto cd6b;
cd63: b1,1f,31            ldb   R31,1f           R31 = 1f;
cd66: c6,30,40            stb   R40,[R30]        [R30] = R40;
cd69: 27,ae               sjmp  cd19             goto cd19;
cd6b: f0                  ret                    return;
Sevensecondsuv
Vehicle Information: 1994 F-350 CCLB 7.5/ZF/4wd
1995 F-250 RCLB 4.9/T18/4wd
2000 Excursion 6.8/4R100/4wd
2001 Ranger RCSB 2.3/M5OD/2wd - turbocharged
2007 Town Car 4.6/4R75E
2011 Ranger SCSB 2.3/M5OD/2wd
wwhite wrote: 2023 Mar 22, 01:20 The total air mass flow into the engine (AMPEM) is computed from the basic equation:
Mass = Pressure * Volume / (Gas Law Constant * Temperature in Rankine)
Because the pressure can not be directly computed it is inferred from engine speed and manifold absolute pressure and a table of volumetric efficiency a a function of engine speed and load.
BASEMD must be calibrated to provide the engine volume for this calculation as well as the Gas Law Constant.
BASEMD = 0.0234393 * Engine Displacement in Liters (lbm - deg R/in. Hg - rev).
SARCHG = Standard Aircharge = 4.4256E-05 * CID / of cylinders.
Are those your words or a quote out of Ford's documentation? If Ford's documentation, do you mind sharing where I can find a copy? It'd be immensely helpful to have Ford's description of how it all works when trying to tune.
Also, I'll note that the equation for basemd presented above returns a far different value than the 225 number that shows up in J1X and SUB2. Maybe that's a unit conversion thing?
The SD4x bins follow the LHBL1 strategy to a T.
So far SUB2 looks like it is missing A/C functions.
Sevensecondsuv
wwhite wrote: 2023 Mar 22, 14:26 The SD4x bins follow the LHBL1 strategy to a T.
That would make sense, this truck wasn't optioned with a/c.
I've implemented all the other patches. Still working on extended VE though. Your code looks good to me but I haven't double checked everything yet.
Going away for a week be offline for a bit.
Haven't had time to finish this up but it has been on my mind. I am taking a trip first two weeks of May so I am hoping to have it done before then.
Sevensecondsuv
Thanks guys.
Finally got around to finishing this up. You should be able to move your EXT VE table over from A1C now and give her a shot.
SUB2 2023-06-07.xdf
(277.27 KiB) Downloaded 352 times
