Heated throttle body necessary?
I was thinking about bypassing the coolant lines since the fittings on the TB are pretty much corroded away. Any thoughts on the subject? This is on a stockish 5.8
Re: Heated throttle body necessary?
I think the coolant through the throttle body is supposed to help the engine warm up quicker when cold.
Probably only effective when below sub freezing temperatures.
Just as good as the aftermarket hot air intakes.
Delete it.
it was never ideal to begin with im frankly amazed it even made it to production
but yes delete it theres nothing good that can come from it no matter how you slice it
Awesome, thanks for all the input guys!
