data dashboard doing some weird things
Covers most all 98 ford cars includes mustang v6, v8, cobra, lincoln town car, grand marquis and crown vic.
Re: data dashboard doing some weird things
Unread post by dleach1407 »
Blocmi wrote: 2023 Mar 07, 14:12
decipha wrote: 2023 Feb 27, 13:59 That means the adx doesn't match the datalogging patch code your using. Two different revisions.
I see two other strategies listed in your bio, CBAZA and RZASA. I'm wondering if there's a sort of bug in the patch code when switching between different strategies and dashboards.
Maybe with the two files you screenshot above laded, try disabling, then re enabling the datalogging patch code with the CRAI8 ADX/XDF. Maybe it would fix the miscommunication if there is one. This may be what decipha way trying to get you to do.
Maybe, I'm not sure how to do that. Anyone have any info on how to do that?
Blocmi
Unread post by Blocmi »
Type "Patch" into the search bar
Select "Enable Data logging patch code"
Follow the directions in the comments to disable and enable
posted the latest and greatest xdf and adx go ahead and snatch them
it was after the last dma patch revision so logging should be the same but just in case should be all good now regardless
decipha wrote: 2023 Mar 09, 16:34 posted the latest and greatest xdf and adx go ahead and snatch them
Thanks! Ill be trying it out tomorrow. If the knock light is still flashing I will pull timing.
Does the N_Load_Knock Histogram show how much timing is being pulled in those areas based on knock sensor feed back?
do you have a knock sensor?
AFAIK, I do. The 96-98 cobras have knock sensors. I havent physically put my hands on them yet though. I took it for a drive last night with the new adx/xdf and the Knock light was still flashing even when idling. I pulled 3 degrees across the whole timing table and it didnt seem to make any difference. I did see the green WOT light turn on a couple times on the dash as well. To eliminate the possiblilty of it being an issue with the software, im going to set up TPRT on my other laptop and do some logging today to see if its the same with a different laptop
did you verify your logging patch is correct?
I think it is. I attached a picture
I just checked and TPRT had an update available. I updated to 5.00.9786.00. Ill retest it today hopefully. The weather is getting bad again.
Just an FYI, the update did not fix the issue. The knock light is flashing or stays lit consistently and the WOT light flashes on occasionally
