Ford Universal ADX
Gav21
Vehicle Information: Ford XG Turbo Ute
XR6 Turbo
XF Falcon
HR31 Skyline
Ford Universal ADX
Unread post by Gav21 »
Hi all im looking for a universal ADX as i cant find one for my Aussie 4L, also ive been trying to enable tracing with my Moates Quarterhorse but keep getting an error sign. Is tracing not available to the QH? Cheers
Re: Ford Universal ADX
you have to make one the only thing universal about my adx is that its standardized so everything is polled in the same order
you still have to find all the ram addresses for all the payloads and patch my datalogging code in your tune
tracing needs datalogging to work
Is finding ram addresses just a guess and check process? Is there a way to view the raw data stream to find things like throttle position easily?
Disassemble the bin, find the ADC routine to get the addresses the input values are stored too. Log those addresses to determine what each channel is, or go through disassembly to work it out.
forgive my ignorance but are all A/D conversions done in the same routine? What opcodes am I looking for?
In most cases ADC is done in one block aside from MAF.
There was a couple examples of the ADC routine in detail here, but is has been flushed in the forum upgrade.
Run the bin through SAD. Search lst for AD_
I'll post an example.
15bee: 03,ec,03           struct    3, iADC_Ch3.1
15bf1: 00,c6,01           struct    0, iADC_Ch0
15bf4: 01,ca,01           struct    1, iADC_Ch1
15bf7: 02,a8,01           struct    2, iADC_Ch2
15bfa: 05,d4,01           struct    5, iADC_Ch5
15bfd: 06,ce,01           struct    6, iADC_Ch6
15c00: 03,ee,03           struct    3, iADC_Ch3.2
15c03: 07,a6,01           struct    7, iADC_Ch7
15c06: 08,a0,01           struct    8, iADC_Ch8
15c09: 09,a2,01           struct    9, iADC_Ch9
15c0c: 0c,d2,01           struct    c, iADC_ChC
15c0f: 03,f0,03           struct    3, iADC_Ch3.3
15c12: 0a,6c,04           struct    a, iADC_ChA
15c15: 0d,8c,04           struct    d, iADC_ChD
15c18: 0e,8e,04           struct    e, iADC_ChE
15c1b: 0f,a4,01           struct    f, iADC_ChF
15c1e: 03,f2,03           struct    3, iADC_Ch3.4
15c21: ff                       ## terminator
# Save A to D values.  Definitons in Structure at 15BEE
     # Vect  from L1646A
   Sbg_82E46_AD_Read:
82e46: a1,ee,5b,34        ldw   R34,5bee         R34 = 5bee;                       # A/D Lookup Structure at 15BEE
     # JNE   from L82E5C Channel requested does not match channel returned
     # SJump from L82E70 Do next Channel listed in Structure 15BEE
82e4a: fb                 ei                     interrupts ON;
82e4b: 56,34,00,04        ad3b  R4,R0,[R34]      AD_Cmd = [R34];                   # get and set, AD channel required
82e4f: de,21              jlt   82e72            if (AD_Cmd >= 0)  {               # SIGNED comparison
     # Cont  for Channels x0 through xF (x7F is positive max)
     # JNB   Loop from L82E51 until AD_Converted=1
82e51: 33,0a,fd           jnb   B3,Ra,82e51      if (AD_Converted = 0) goto 82e51; # wait for AD conversion
82e54: fa                 di                     interrupts OFF;
82e55: 51,0f,04,38        an3b  R38,R4,f         R38 = AD_Low & f;                 # get channel returned
82e59: 9a,34,38           cmpb  R38,[R34]                                          # check correct channel
82e5c: d7,ec              jne   82e4a            if (R38 != [R34]) goto 82e4a;     # No, try read again
     # Cont  Channel requested matched Channel returned
82e5e: 51,f0,04,38        an3b  R38,R4,f0        R38 = AD_Low & f0;                # AD Low value
82e62: b0,05,39           ldb   R39,R5           R39 = AD_Hi^;                     # AD High value
82e65: 07,34              incw  R34              R34++;                            # incr ptr to iADC address
82e67: b2,35,36           ldb   R36,[R34++]      R36 = [R34++];                    # get iADC address, lo then hi
82e6a: b2,35,37           ldb   R37,[R34++]      R37 = [R34++];
82e6d: c2,36,38           stw   R38,[R36]        [R36] = R38;                      # save AD value to iADC address
82e70: 27,d8              sjmp  82e4a            goto 82e4a; }                     # Do next AD
     # JLT   from L82E4F negative (x80 to xFF) is less than 0
82e72: 07,34              incw  R34              R34++;                            # [15C22] Struct terminator +1
82e74: ad,02,46           ldzbw R46,2            wR46 = 2;                         # Why not 1???
82e77: 08,01,46           shrw  R46,1            R46 >>= 1;                        #[ R46 /= 2]   # R46=1
     # JNE   from L82EB2
     # SJump from L82EBF
82e7a: 56,34,00,38        ad3b  R38,R0,[R34]     R38 = [R34];                      # x02
82e7e: de,41              jlt   82ec1            if (R38 >= 0)  {                  # Terminator
82e80: c4,39,38           stb   R38,R39          R39 = R38;                        # x02
82e83: 93,47,ce,5b,38     orb   R38,[R46+5bce]   R38 |= [R46+15bce];               # [15BCF] x42 |= x2 x40
82e88: 28,38              scall 82ec2            Sub82EC2_yLSSO_A=yR38 ();         # Write LSSI#A
82e8a: b1,03,42           ldb   R42,3            R42 = 3;
     # DJNZ  Loop from L82E8D
82e8d: e0,42,fd           djnz  R42,82e8d        R42--;
                                                 if (R42 != 0) goto 82e8d;         # Wait
     # JE    from L82E9D
82e90: b0,15,36           ldb   R36,R15          R36 = LSSI#A;                     # Read LSSI#A
82e93: 73,47,d0,5b,36     an2b  R36,[R46+5bd0]   R36 &= [R46+15bd0];               # [15BD1] LSSI#A&=xE0 B4..B0 cleared
82e98: 9b,47,d2,5b,36     cmpb  R36,[R46+5bd2]                                     # [15BD3] x40
82e9d: df,f1              je    82e90            if (R36 = [R46+15bd2]) goto 82e90;  # B6_LSSI#A Set 1
82e9f: fa                 di                     interrupts OFF;
82ea0: b0,19,3b           ldb   R3b,R19          R3b = LSSI#C;
82ea3: b0,17,3a           ldb   R3a,R17          R3a = LSSI#B;
82ea6: b0,15,36           ldb   R36,R15          R36 = LSSI#A;
82ea9: fb                 ei                     interrupts ON;
82eaa: 93,47,d4,5b,39     orb   R39,[R46+5bd4]   R39 |= [R46+15bd4];               # [15BD5] xC1 |= 1 xC0
82eaf: 98,39,36           cmpb  R36,R39
82eb2: d7,c6              jne   82e7a            if (R36 != R39) goto 82e7a;       # LSSI#A != xC1
82eb4: 07,34              incw  R34              R34++;                            # [15C23]
82eb6: b2,35,36           ldb   R36,[R34++]      R36 = [R34++];                    # Lo Value
82eb9: b2,35,37           ldb   R37,[R34++]      R37 = [R34++];                    # Hi Value
82ebc: c2,36,3a           stw   R3a,[R36]        [R36] = R3a;                      # Save AD Value to iAICE address
82ebf: 27,b9              sjmp  82e7a            goto 82e7a; }
     # JLT   from L82E7E
82ec1: f0                 ret                    return;
I am single bank SD and I don't see anything resembling the first example. But I found this:
   Sub_3af0:
3af0: a1,1e,3b,30         ldw   R30,3b1e         R30 = 3b1e;
3af4: fb                  ei                     interrupts ON;
3af5: 56,30,00,04         ad3b  R4,R0,[R30]      AD_Cmd = [R30];
3af9: de,22               jlt   3b1d             if (AD_Cmd >= 0)  {
3afb: 33,0a,fd            jnb   B3,Ra,3afb       if (AD_Ready = 0) goto 3afb;
3afe: fa                  di                     interrupts OFF;
3aff: ff                  nop
3b00: 51,0f,04,34         an3b  R34,R4,f         R34 = AD_Low & f;
3b04: 9a,30,34            cmpb  R34,[R30]
3b07: d7,eb               jne   3af4             if (R34 != [R30]) goto 3af4;
3b09: 51,f0,04,34         an3b  R34,R4,f0        R34 = AD_Low & f0;
3b0d: b0,05,35            ldb   R35,R5           R35 = AD_High;
3b10: 07,30               incw  R30              R30++;
3b12: b2,31,32            ldb   R32,[R30++]      R32 = [R30++];
3b15: b2,31,33            ldb   R33,[R30++]      R33 = [R30++];
3b18: c2,32,34            stw   R34,[R32]        [R32] = R34;
3b1b: 27,d7               sjmp  3af4             goto 3af4; }
3b1d: f0                  ret                    return;
3b1e: 01                  byte      1
3b1f: 0e                  byte      e
3b20: 01                  byte      1
3b21: 02                  byte      2
3b22: 0a                  byte      a
3b23: 01                  byte      1
3b24: 03,0c,01,07,1c,01,08,10,01,09,12,01,0a,18,01,0b  ???
3b34: 1a,01,0c,14,01,ff   ???
efloth wrote: 2021 Feb 20, 14:43 I am single bank SD and I don't see anything resembling the first example.
          Ch.     Addr.
3b1e:...   1       10e
3b21:...   2       10a
3b24:....  3       10c
07,1c,01,..7       11c
08,10,01,..8       110
09,12,01,..9       112
0a,18,01,..a       118
0b  ???  ..b       11a
0c,14,01,..c       114
ff   ???
You do, it is right there, hiding in plain sight.
R30 = 3b1e tells you where to look. Use a str command in your SAD DIR to format it. Use sym commands in your SAD DIR to name the addresses.
SYM  10E "iADC_Ch1"
STR 3B1E 3B39 $Q1 :Y :WN                  # AD Conversion Structure
Thanks, got it. Here is the result:
3b1e: 01,0e,01            struct    1, iADC_Ch1
3b21: 02,0a,01            struct    2, iADC_Ch2
3b24: 03,0c,01            struct    3, iADC_Ch3
3b27: 07,1c,01            struct    7, iADC_Ch7
3b2a: 08,10,01            struct    8, iADC_Ch8
3b2d: 09,12,01            struct    9, iADC_Ch9
3b30: 0a,18,01            struct    a, iADC_ChA
3b33: 0b,1a,01            struct    b, iADC_ChB
3b36: 0c,14,01            struct    c, iADC_ChC
Please correct me if I am wrong, the above addresses are not directly readable by the QH so they are being copied by the datalogging routine to readable addresses. The ADX is configured to read shadow addresses so the big question is in what order are these shadowed? My Datalogging List function below is a copy from the A1C DL Patch. Can I assume that 010a=00D6? I think I am missing part of the equation. Thanks for all your help.
00D6
0396
00B6
009A
00CC
00BA
00B4
0124
008A
0162
01F2
00BE
0096
0170
011A
0154
0092
008C
0090
00B8
00B2
00A8
015C
016A
00DA
021A
0228
014E
0238
00D8
035C
0314
0322
016C
0398
0000
0027
5D01
009E
4404
00A5
4480
0000
0000
