Hello everyone,
Does anyone have published injector data for Delphi/Lucas 96lb low impendance injectors? Same injector that is rebranded and sold by TFS, Accel/Holley, and they are not responding to my request currently.
Thanks,
M. Miller
hello
96lb low impedance injector data
Blklightning1
- Vehicle Information: 2000 Ford Mustang GT
Re: 96lb low impedance injector data
No sry. All of us use high impedance injectors.
Is it giving you trouble dialing her in?
Blklightning1
Yes and no, I have had some issues in the past that actual AFR where not matching commanded AFR. This is a fairly high boost (25lb) on E85 application. I just wanted to remove that possible variable.
Boost is irrelevant and unaffected. Proper injector data only affects decel and low flow where the injector is non linear.
If your having fueling inconsistencies at anything over half throttle then the injectors either arent the issue or are faulty.
Blklightning1
I understand, I have found the information. Due to how the injection driver circuit reacts between 13 - 14 volts the battery offsets are that typically used were causing inconsisitent part throttle/decel fueling that no amount of "traditional" change would have corrected. Holley gave me the information. I am back on track now.
Thx for trying to assist!
