my experience with going back to SD
S/D specific subforum for the Gen-1 Lightnings,
88- Tbird/Stang/Lincoln/Mercury, RV's, and Trucks.
Re: my experience with going back to SD
Unread postby YaBoyHalle » Fri Jan 16, 2015 1:58 pm
check it ooooouuuuut! this is the cylinder 8 spark plug, the usual problem child. same blackness. brand new plugs, after 100 miles.
i replace the eec relay, and some other, and that seemed to help. same with the TFI module (lifetime warranty. i'm sure i'll use it plenty of times.)
now the misfire is barely noticeable and happens less frequently. not at idle anymore, which is good. start ups are reliable now.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Fri Jan 16, 2015 4:19 pm
that plug looks horrible, might want to consider running a hotter plug
Unread postby YaBoyHalle » Fri Jan 16, 2015 5:41 pm
right? im running 1924's, and i initially assumed i had 23's (colder) and thought the same thing. here's the side of the ground strap.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby YaBoyHalle » Fri Jan 16, 2015 5:57 pm
also, for future consideration, would you ever do an online tune of caledit? i know the logs are basically useless. but i was wondering none the less.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Fri Jan 16, 2015 6:19 pm
well damn shes got plenty heat in her
yea I do caledit tunes all the time
Unread postby YaBoyHalle » Fri Jan 16, 2015 6:39 pm
yeah, exactly. forgot about the wot x fuel mult. (put to 1) leaned out the majority of startup, idle was stock rich too (.94). all leaned out. she's pretty peppy at the moment, even at startup, tip in and idle are very stable. i just wish i knew where the afr was at during wot.
and how the hell are you supposed to read the logs?
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Fri Jan 16, 2015 8:15 pm
with calcon
Unread postby YaBoyHalle » Fri Jan 16, 2015 10:04 pm
well yeah, but i get a horribly plotted graph. maybe i'm not seeing it right.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Fri Jan 16, 2015 11:46 pm
do you have the latest caledit/calcon update?
Unread postby YaBoyHalle » Sat Jan 17, 2015 1:40 am
yep. it'll show ect correctly, and then everything else is a very small line at the bottom.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Sat Jan 17, 2015 9:45 am
select a different payload to change the scaling
Unread postby YaBoyHalle » Sat Jan 17, 2015 4:52 pm
it will only change the x-axis, which is time. which ruins the graph. i can't find a way to change the y-axis, which would be correct.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby YaBoyHalle » Wed Jan 21, 2015 10:15 pm
went logging for a good long while; the car has somehow gone incredibly rich under all conditions (lambse of 17). was fine back then, not sure when it happened. i leaned it out again, fuel in CL is spot on. the misfire is still random, not always a big deal, sometimes the car bucks. and on top of that, engine oil is starting to disappear.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby YaBoyHalle » Thu Jan 22, 2015 9:58 pm
good new: unplugged EGR and the misfire is GONE. completely. either it's open more than it should? or maybe afr heads can't handle as much. egr on with spark add off has the same effect, so the spark wasn't doing it.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby YaBoyHalle » Sat Jan 31, 2015 6:47 am
misfire is back. usually at low rpm's. ODDLY, only in drive. does drive idle air flow have an effect on this i wonder? because that was messed up.. it certainly dies easier in drive. i'll experiment..
found the oil leak, valve cover bolt were ALL loose. i could take them off with two fingers. tightened them, and now all that's left is the main seal.
now that i'm logging spark, i noticed that spark stays at 25.75 at idle. goes up to 50 on the decel, jumps to 25.75, and just stays there. so no idle spark control.
idle neutral spark is there in the strat, but it's invalid. idle drive isn't even there. i guess i'll have to bug Glover ONE last time...
and i suddenly had a weird issue of caledit saying "bank count too big for current calibration. check and try again." or something along those lines. even reading the stock tune and writing that caused the error! i tried a bunch of different things and it randomly starting working again. i think it was the littler prayer i did that fixed it lol.
it's also running lean on start up! why does it always do this! i need to grab a gas gauge. once it goes rich it stays rich though.
jesus my car HATES the cold. or the fog. or me.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Sat Jan 31, 2015 8:51 am
the car loves you it just has an odd way of showing it
Unread postby YaBoyHalle » Sun Feb 01, 2015 12:08 am
putting numbers into the error filled spark idle neutral somehow fixed BOTH neutral and drive. so those are working. BUT it still goes lean on start up.
i noticed your spark table on the a9l2 scales spark more going down in rpm than the stock D9S, (new table posted on the spark thread) so maybe that could be too advanced? would being too advanced down low cause, not audible pinging, but bucking/missing?
if it doesn't fix it, i'll have to run through all the possible hardware.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Sun Feb 01, 2015 3:04 am
most bucking is due to too little dashpot
if its heavily over advanced, yes it can cause bucking
Unread postby YaBoyHalle » Sun Feb 01, 2015 4:17 pm
well she's done it now. the car doesnt want to start. on a recent drive through heavy fog it randomly start puking gas, while the hego's were still bouncing around, started bucking HARD, started halfway dying when the throttle was too low. wasted 5 gallons of gas trying to get it home. stopped at a gas station with not a single gallon left and died. codes 24 and 15- act out of range and KAM test failure. the engine light stayed on while driving, but was dimming with rpm's. i had plenty of coolant, oil, nothing fell off, nothing was obviously wrong. i managed to give it gas and crawl it home keeping it above 2k. smelt rich as hell but i remember the hegos were bouncing around fine drive before last.
I'm going to give ME time to cool off before i even think of this car again. i might just leave it there and take a train back to sacramento to finish entering the air force. or i might drive it off a cliff. either way.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby ranga83 » Tue Feb 03, 2015 5:04 am
mine did that a while ago and I found the vac line to the MAP kinked. have you looked into a faulty map?
ranga83
Unread postby YaBoyHalle » Tue Feb 03, 2015 12:04 pm
i was going to drive the car to a junkyard the next day to get a couple MAPs, among other things.
the one good log i have of driving it to the station had the MAP showing normal readings, the only oddity is the ect is 214 when it's normally right under 200.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby ranga83 » Tue Feb 03, 2015 5:57 pm
Whats your ve vs ECT multiplier set at? Its not too high at higher temps is it?
ranga83
Unread postby YaBoyHalle » Tue Feb 03, 2015 6:31 pm
i only see a VE correction vs. ACT. Can't find one for ECT.. ACT admittedly gave a code reading for out of range, and in the log it started at 190 and moved down to 150 and switched between them frequently. at 150 it's 1, 180 it's 1.04, and 254 at 1.1875.
1.04 doesn't seem TOO bad, but ACT at 190 on a 40 degree night does.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Tue Feb 03, 2015 7:28 pm
well thats your problem
ACT is a critical input
Unread postby ranga83 » Tue Feb 03, 2015 8:29 pm
Oopps. I meant ACT. Wasnt near my laptop to confirm it
ranga83
Unread postby YaBoyHalle » Tue Feb 03, 2015 11:39 pm
oh really? ACT isn't a big deal to replace. lil bit of thread lock, and bam. i'll pass word to my step dad, see if he wants to replace it and try to run the engine.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby YaBoyHalle » Mon Feb 09, 2015 1:57 pm
i'm told he's run the car around the neighborhood. ACT was the culprit of course. i'll have to pick it up and make sure it's trip ready. i'll have to plan to give it a total tune up, all the necessary sensors will be replaced. what's your favorite brands?
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Mon Feb 09, 2015 2:28 pm
i like duralast, never an issue with the zone stuff
I wouldn't go replace anything you don't need to
Unread postby YaBoyHalle » Mon Feb 09, 2015 5:29 pm
hmm. just duralast then?
my thinking is that everything i havent touched is bad or will go bad as soon as i'm not expecting. like you say with the eec power relay (which i HAVE replaced, but there's still a few more up there.) it seems to me that everything that others fiddle with fail often. I'd feel a lot better knowing that this won't happen again, hours from home.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Mon Feb 09, 2015 6:19 pm
well maf, act, and tfi / pip are the only important ones
dont make the mistake of thinking just cuz its new that it wont fail
Unread postby YaBoyHalle » Tue Feb 10, 2015 2:52 am
well i gladly don't have a maf. but i had a failed map once, replaced with a random shop pile oem find. i have a new tfi from oreilly's, and the original ford back up with tools in the trunk. act is really that important? i never knew it was THAT big.
any other big ones?
and besides the act mult vs fuel and act retard, what else (in general) does it do? it would help fill in holes in my knowledge.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Tue Feb 10, 2015 8:23 am
ACT is the third most critical input, its used in the airmass calculation, air temperature affects air density and if the computer doesn't know the actual ACT or if its failed then it uses a substitute value (default ACT) and the airmass calculation will be off
with airmass off, the calculated fuel pw will be off, and the spark look up (load) won't be optimal either
for reference
1> TFI
2> MAF / MAP
3> ACT
4> IEGO1
5> ECT
7> TPS
Unread postby YaBoyHalle » Thu Feb 12, 2015 6:15 pm
sweetness. just got back to the car, and in celebration of it working (pretty damn well now) my friend and i rampaged through town setting off car alarms with our open exhaust. i was giddy. startup is a bit messy, but i think it's because i messed with ACT vs. OL fuel mult. but once it's warmed up it fantastic!
now i just have to find the odd afterfire...
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby YaBoyHalle » Thu Feb 19, 2015 6:44 pm
well THAT was fun. my internet has been out for a while since switching to comcast, and a few events played out during my little black out. ok, first thing first,
timing cover coolant leak. pretty bad. got aaaall the way down to the chain and aaaall the way up. only cost me $40 for it all, so i saved 700 by not taking it to a shop. still, it's a PITA.
taking the old oil/water mix to the closest parts store, and it dies in park. my new fuel pump relay bit the dust. order a warranty replacement, plug in the old eec relay to get me home, put the new FP relay in the next day. VE table is off at idle now, fixed that.
oh hey, did not notice my lower rad. hose had fallen apart and was gushing. order that (one hour delivery, sweetness.) put that back on and fill up the radiator. and wait, what happens next?
it drives perfectly. i mean perfect. starts up exactly like i ask it to. idles like i ask it to. cruises like it's brand new. no misfires, no water leaks, mpg seems like it's normal again, everything. It's. Finally. Happy.
on a side note, is it fine to make engine brake decel's OL and a bit lean? for the burble sound. maybe like, 15 afr? it has adaptives off in that area as well, pointing to -20 per stock.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Thu Feb 19, 2015 8:29 pm
cool, yeah lean decel wont hurt nuthin, Ive had lean decels in the 19s+ for those with deep exhaust to give it that rumble, sounds bad ass on my ls1 camaro
Unread postby ranga83 » Fri Feb 20, 2015 5:42 am
I run decel at about 19 aswell. Never had any issues
ranga83
Unread postby YaBoyHalle » Sun Feb 22, 2015 5:04 am
shiiiiiiiiiiiiit no start. cranks, no spark. 12 volt to coil, 12 volt to inj positive wire, to ign switch, fuel and eec relay are good, changed tfi's to a known good one, change dizzy to a known good one. my last idea is ordering a computer.
Help me out! it's stranded downtown. just list any ideas you can and i'll check them out.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Sun Feb 22, 2015 11:47 am
check fuel pressure
plug in and see if the rpms are reading so you know if the tfi is working
then check to make sure the mafv is reading during crank too
Unread postby YaBoyHalle » Sun Feb 22, 2015 2:07 pm
No maf... But I'll plug in the laptop to check the tfi. I dont have a fuel pressure gauge, but i jumped the pump circuit to make sure it runs.even if it didn't have fuel it would still spark though. I've unplugged all the sensors, one at a time, to see if theres a difference but no. Coil was switched to a known good as well. Nothing makes a least bit difference in it cranking.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby red5.0fogger » Sun Feb 22, 2015 2:33 pm
Bad coil wire to center of dist cap or bad cap/rotor? Something was adjusted in the tune lately?
Premium Member
PreviousNext
Return to Speed Density Tuning
