EFI-SD40a
S/D specific subforum for the Gen-1 Lightnings,
88- Tbird/Stang/Lincoln/Mercury, RV's, and Trucks.
Re: EFI-SD40a
Unread postby decipha » Sun Aug 02, 2020 12:44 pm
lol
Name: Michael Decipha Ponto
Other Vehicle(s): Others:
06 Chrysler 300 AWD - Sharifa
Re: EFI-SD40a
Unread postby JETFAST » Sun Aug 16, 2020 8:53 pm
got my I-6 going with a t3/t4 @ 6 psi, Stock injectors and a vortec FMU on the return. sounds like big truck, pulls like one too.
JETFAST
Vehicle Information: Horsepower Breader
Re: EFI-SD40a
Unread postby efloth » Wed Aug 19, 2020 5:14 am
Nice! What exhaust manifold did you use? Did you get that MAP check valve working?
Vehicle Information: 1991 F150 4.9L on E85
Siemens Deka 80LB Injectors
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby efloth » Mon Aug 24, 2020 12:00 pm
It looks like the CEL is fuel related. When cold I was going too rich. Still suffering from some serious dwell on these injectors compared to stock. How do these Injector Offset values look for 52 PSI? Should I be calculating for regulator or pump pressure? Anything else I should be looking at? It runs almost perfect but rich/lean swings are between .80 and 1.2 on the ve histogram but still averaging around 1
0.00    2.500
6.00    2.188
12.00   0.906
13.00   0.750
14.00   0.656
15.00   0.563
15.94   0.450
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby JETFAST » Fri Aug 28, 2020 2:42 pm
efloth wrote:Nice! What exhaust manifold did you use? Did you get that MAP check valve working?
I removed the muffler, and rear mounted it just behind the cab. Work around the shop has been busy, and i have not had time to mess with it. I am currently running it with out a check valve, and it works as needed. Drive it everyday. As more time allows I will address the situation better. came from be/ea, and i am still learning my way around the TP/RT software. Have not been able to do any data logging as of yet, but I do have a gauge on the O2 sensor, and closed loop is working good, no CEL's. Just need more free time with it.
JETFAST
Re: EFI-SD40a
Unread postby JETFAST » Wed Sep 09, 2020 12:17 pm
would you mind if I post the current tune I am running in here for review? or should I start a new thread?
JETFAST
Re: EFI-SD40a
Unread postby decipha » Wed Sep 09, 2020 12:28 pm
just start a new one
Re: EFI-SD40a
Unread postby motorhead1991 » Thu Sep 10, 2020 1:04 pm
I have a carb head I can use to build a couple manifolds if anyone is interested.
I'll have to get a fuelie intake so I know where I have clearance.
motorhead1991
Other Vehicle(s): Stock 1990 Ranger. ICM relocation, Volvo 31lb Bosch injectors, custom tune, e85: 82hp/103tq
Re: EFI-SD40a
Unread postby efloth » Fri Sep 11, 2020 10:57 am
Making progress with fueling consistency @ 52psi on the 80s. I wanted to see if I could get it right without lowering fuel pressure. Quick question: does FN367W (Injector Offset Voltage) simply add to the final calculated injector pulse? I started with the correct curve and experimented with lowering PW by .02 until things improved (increasing the PW made it worse so this is counterintuitive). I have experienced a noticeable power increase and fewer CELs but I am at .100 @ 14v. VE looks good and I am not going super rich on decel any more. Am I just overcompensating for some other issue in the tune? Any input would be appreciated.
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Wed Oct 14, 2020 5:58 am
I'm late didn't see this reply but if you need to reduce the offset that much to get decel fuel under control then most likely your VE tabel in the decel areas needs to be reduced significantly.
Previous
Return to Speed Density Tuning
