[LUX0] Swapping a 4cyl. EEC for a V8 one - FB1 -> DA1
S/D specific subforum for the Gen-1 Lightnings,
88- Tbird/Stang/Lincoln/Mercury, RV's, and Trucks.
Unread postby mustangdriver » Thu May 16, 2019 2:00 pm
Hi Folks,
I signed up here because I want to report on the conversion and maybe need support.
Have a crazy idea :idea: years ago the user "vristang" already made in a similar way.
On the engine, I have changed the following: exhaust header, 2 1/4" exhaust pipe, ´05er muffler, cylinder head milled, compression 10.2: 1, ported ports, roller camshaft, new valves, intake manifold ported, resonator removed.
anyway...
I have 3 EECIV - FB1, FC1, 8CB. They all work, but the programming has not been done very well by Ford.
Also, there is no definition file for it (I've tried to create one)
Now I have bought an EEC "DC" for $ 44.50 on ebay. Will be soon in good old germany.
I don´t want to MAF or EDIS stuff .... but just program my wishes for a proper engine run.
I have a definitionfile LUX0 from the Tunerpro website. I have already extended this, will post the changes here.
Furthermore, I have the binfiles DA1, DB1, DC, DE. I'm working with Tunerpro. What is unknown in the definitions file I change to byte level and look at the result with Caledit. There is still a lot to do :o
I have created schematics to see which pins are needed.
Very important: My injectors have 16ohms! (14lbs/hr) high impedance, no change :mrgreen:
Now my question:
Which pins will be plugged in for the 4 cylinder controls on the 8cyl computer? E.G. injectors 1-4 not 5-8...or injector outputs 1,3,5,7 but I am a bit confused on all of this at the moment. I would assign the each cylinders to their respective injector output port mapping, and run it like that? :?: Firing order of the engine is 1342 :lol:
So - apologize in advance for the long newbie post. Thanks for all input.
Tobias
my english is not good, but my Mustangs are top :)
mustangdriver
Vehicle Information: 87 LX convertible 2.3 FB1 5 speed manual FB1 now DA1
Vehicle 2 Information: 79 V8 347cui
Edelbrock Heads, Carb, Manifold, V2a Headers, X-pipe, 340HP
Re: Swapping a 4cyl. EEC for a V8 one - FB1 -> DA1
Unread postby mustangdriver » Fri Jun 07, 2019 3:47 am
Hello my american friends,
The engine is running!!!!
is a pity none of you could help...thanks to German thoroughness, I hacked the strategy so far that I found all the parameters I needed for the 4 banger.
I have soldered an LED to each injector port so I can control the programmed injector firing order. Instead 1-3-7-2-6-5-4-8 is now 1-3-4-2. The other 4 LEDs remain dark.
After many experiments, where the engine ran bad, I found the right values in binfile. It is not easy, because there are some values double / triple. :cry:
Youtube: https://youtu.be/dwBVidkZR4c
I changed the following:
Injector Firing Order=1,3,4,2,0,0,0,0
Injector Output Port=0,0,0,0,0,0,0,0
DEGPIP=180
SPKSWL=1307
SPKSWH=1307
NUMCYL=4
NUMOUT=4
PIPOUT=4
ENGCYL=2
MHPFD=0.29
THRMHP=0
PFEHP=2
NUMHEGO=1
SARCHG=140
Injector High Slope=14
Injector Low Slope=20
I did not find the SIGKLU and SIGKLL . :shock:
I am happy to provide the defintionsfile unencrypted.
Tobias
mustangdriver
Unread postby decipha » Fri Jun 07, 2019 10:31 am
very nice work tobias
are you sure about the degpip scalar? should be 180 but im thinking you have it enumerated some type of way so 4 means 4 cylinder?
do u have datalogging?
Name: Michael Decipha Ponto
06 Chrysler 300 AWD
Unread postby mustangdriver » Sun Jun 09, 2019 2:36 pm
sorry, my mistake, I mean 180 of course... :mrgreen:
No Datalogging :?
mustangdriver
Unread postby motorhead1991 » Mon Jun 10, 2019 10:08 am
mustangdriver wrote:sorry, my mistake, I mean 180 of course... :mrgreen:
No Datalogging :?
That can easily be fixed.
motorhead1991
Vehicle 2 Information: Stock 1990 Ranger. ICM relocation, Volvo 31lb Bosch injectors, custom tune, e85: 82hp/103tq
Unread postby mustangdriver » Thu Jun 13, 2019 1:53 am
Da1_test_4cyl_parameter.bin
LUX0_tobi.xdf
Hi,
here are the updated files!!!!
Edit July 3.
mustangdriver
Unread postby motorhead1991 » Thu Jun 13, 2019 12:42 pm
mustangdriver wrote:Hi,
Did you look at the other DA1 thread? I set up the datalogging patch on lux0
motorhead1991
Unread postby mustangdriver » Sat Jul 06, 2019 5:25 am
...yes, but i have no Tweecer/QuarterHorse :cry: :x
My car----->
Tobias
mustangdriver
Unread postby mustangdriver » Wed Jul 31, 2019 8:31 am
----> updated Files, Aug. 12, 2019:
Shiftlight - working
DFSO - working
closed loop PT + idle - working
smooth transient idle to part throttle - working
cold start - 1200rpm after a few seconds 850rpm
WOT - up to 3000rpm stoich, then 13:1 AFR
Dashpot decay - working
Spark advance PT and WOT - at the advance limit :o
mustangdriver
Unread postby mustangdriver » Wed Jul 31, 2019 9:43 am
I've moved my ecu under the seat so I can get to the J3 port.
mustangdriver
Unread postby mustangdriver » Thu Aug 22, 2019 4:56 am
Newest definition file LUX0
Does anyone want to develop this file further? :idea:
LUX0.xdf
mustangdriver
Unread postby mustangdriver » Sat Sep 14, 2019 4:38 pm
Newest definition file LUX0 :idea: :arrow: 8-)
LUX0.xdf
DE_DA1_64k_ex12.BIN
mustangdriver
Unread postby motorhead1991 » Tue Sep 17, 2019 8:58 pm
Get a Quarterhorse and try the datalogging code :grin:
motorhead1991
Unread postby Mikestang » Tue Sep 17, 2019 9:18 pm
mustangdriver wrote:Newest definition file LUX0 :idea: :arrow: 8-)
LUX0.xdf
DE_DA1_64k_ex12.BIN
Did Derek send this out. I found 2 missing pieces a while back and he sent me an updated LUXO
Everyday I learn how much I don't know....
Mikestang
Vehicle Information: 1986 Ford Mustang GT, Sonic Blue
347 Stroker, custom cam, 185 CNC Trick Flow heads w/PAC springs
Trick Flow upper and lower extrude honed
(many more mods...)
Moates QH chip
Binary Editor software w/Innovate software
A3M1
Vehicle 2 Information: 1981 Mustang SCCA A-Sedan car Restored by Me
86 Capri EFI 5.0L Engine
Mostly Stock, F-cam, Valvetrain upgrades, Long Tube headers
DA1 PCM, Using BE and QH with Innovate AFR
Unread postby mustangdriver » Thu Oct 03, 2019 11:23 am
LUX0.xdf
DE_DA1_64k_ex12.BIN
No, I have developed in hours/days of work.
which missing pieces?
mustangdriver
Unread postby mustangdriver » Thu Oct 03, 2019 11:38 am
LUX0.xdf
DE_DA1_64k_ex17_egr_on__last_4_scalar_from_dc.BIN
mustangdriver
Unread postby Mikestang » Mon Oct 07, 2019 11:56 am
LUX0.xdf
DE_DA1_64k_ex12.BIN
In mine there was no " Cranking ISC Duty Cycle", cant recall the other one at this time.
Mikestang
(many more mods...)
Moates QH chip
A3M1
Unread postby mustangdriver » Wed Oct 09, 2019 9:15 am
Do you have a binaddress? Or a PID, for example, as in the screenshot? I could add that to the defintionsfile for Tunerpro.
mustangdriver
Unread postby mustangdriver » Wed Oct 09, 2019 9:36 am
DE_DA1_64k_ex25.BIN
LUX0.xdf
The last bits in the binfile have a big effect. (9F8A, 9F8C, 9F8E)
Cold start on DC/DE adjustment: runs quietly at 1000 rpm.
Cold start on DA1/DB1 adjustment: Motor goes off the first time, then runs at 1500 rpm and goes off after approx. 5 sec - maybe "Cranking ISC Duty Cycle"?
mustangdriver
Re: [LUX0] Swapping a 4cyl. EEC for a V8 one - FB1 -> DA1
Unread postby mustangdriver » Wed Dec 11, 2019 4:43 am
Hi,
newest Files here ;)
LUX0.xdf
DE_DA1_64k_ex28_afratio.BIN
DE_DA1_64k_ex28_afratio.rar
Motor runs very well...top speed on german autobahn 112mph / with open convertible top I drove 105 mph.
In the winter I do not drive the convertible, so it's time for a break.
Unless I'm on the crazy idea to install a V8. :lol: :mrgreen: :idea: :P
mustangdriver
Unread postby decipha » Wed Dec 11, 2019 6:13 am
what is the max speed your 2.3 will do ?
06 Chrysler 300 AWD
Unread postby mustangdriver » Mon Feb 17, 2020 3:27 pm
115mph.... :?: :mrgreen: maybe
New year...new camshaft
mustangdriver
Return to Speed Density Tuning
