EFI-SD4X strategy and 351W 60# inj A0 inj slope value
S/D specific subforum for the Gen-1 Lightnings,
88- Tbird/Stang/Lincoln/Mercury, RV's, and Trucks.
Unread postby bobwhite » Thu Sep 20, 2018 10:39 am
when i open the 351W 60# inj base tune with the EFI-SD4X strategy in tunerpro rt the value displayed for AHISL-Injector High Slope is 16.001 #/hr ? am i overlooking something obvious or is this value the result of a scaling divisor ? shouldn't it be around 60 #/hr ? the fn1320 and fn1420 ve table values are also very low. i would like to try this tune on my gen1 Lightning with oem 19# injectors, but need to make some changes to the inj slope and any other injector related changes or other changes not proper for my truck. i'm curious to see how it will idle with the mechanical idle settings of the 351W base tune. i've read the write-ups, but haven't noticed anything that applies to this SD situation. i use tunerpro rt to build my tune and then load it into the TwEECer RT using CalEdit. all insight appreciated.
bobwhite
Vehicle Information: 93 lightning, EEC4 SD, C3P2 bin, LHBL0 strat, TwEECer RT, CalEdit
Re: EFI-SD4X strategy and 351W 60# inj A0 inj slope value
Unread postby decipha » Thu Sep 20, 2018 12:31 pm
I wouldn't recommend using that on a stock-ish setup, much better to take a stock icy1 bin and edit it for your needs being stockish
Unread postby bobwhite » Thu Sep 20, 2018 1:56 pm
good enuff, i'll modify my tune to be mechanical idle . just figured i'd ask what's going on in that tune. thanks a lot
bobwhite
Unread postby decipha » Thu Sep 20, 2018 5:10 pm
i would recommend against that being speed there is a lot of emphasis on airflow modeling being correct
Unread postby bobwhite » Thu Sep 20, 2018 7:47 pm
ok, thanks again.
bobwhite
Return to Speed Density Tuning
