Idle problems with AC on
S/D specific subforum for the Gen-1 Lightnings,
88- Tbird/Stang/Lincoln/Mercury, RV's, and Trucks.
Unread postby fernando_221 » Sun Sep 17, 2017 3:56 pm
Hello all,
I have a turbocharged Ford Focus (2.0 Duratec), I'm using SCT to tune it and I'm trying to get a solid idle. With AC off the idle is good, if I turn AC on the idle start to go up and down. The idle rpm is set to 850rpm, when I turn on the AC it starts to oscilate from 500 rpm to 1000rpm, it's very annoying. If I apply load to the power steering it gets even worse and sometimes stalls.
I run ethanol, the camshafts are stock, Siemens 60lbs injectors and a Cosworth intake manifold.
Can anyone help? I posted this at SCT Forum but no response yet.
Below I posted a log, at TS 100 I turn on the AC and you can see how the idle changes.
Log
https://drive.google.com/file/d/0B9JlWE ... sp=sharing
fernando_221
Vehicle Information: Ford Focus Turbocharged tuned with SCT Advantage III, WNCDAQ4 strategy
Re: Idle problems with AC on
Unread postby decipha » Sun Sep 17, 2017 4:20 pm
kick up the a/c idle airmass ppm function to give it more air to idle correctly
Unread postby fernando_221 » Sun Sep 17, 2017 8:21 pm
decipha wrote:kick up the a/c idle airmass ppm function to give it more air to idle correctly
Hi Decipha, I think I don't have a specific function for the a/c, here is what I have for idle:
fernando_221
Unread postby decipha » Sun Sep 17, 2017 8:24 pm
that sucks, maybe contact sct and ask them to add it, fn881 functions
Unread postby fernando_221 » Sun Sep 17, 2017 8:48 pm
decipha wrote:that sucks, maybe contact sct and ask them to add it, fn881 functions
I'll contact them and ask to add the functions, thanks.
Is there anything I can do to improve the idle until sct add the functions?
Thank you
fernando_221
Unread postby fernando_221 » Sun Sep 17, 2017 9:35 pm
Is there a definition for my ecu? Strategy is WNCDAQ4. If not, how can I create it? Is it possible to tune my ecu with TunerPRO or Binary Editor?
fernando_221
Unread postby decipha » Mon Sep 18, 2017 2:55 pm
no def that im aware of
your ecu is a can bus ecu is doesnt have a j3 port, so although u can tune it you wouldnt be able to write it
all the details for making a def file is on the homepage, swap the intel disassembler for ida disassembler and all else is basically the same
Unread postby Drew@DMP » Wed Sep 20, 2017 9:17 am
Hows your Idle air integrator doing at idle? whats your IAC duty cycle? I've done a lot of Fords with SCT and have used the A/C neutral adder or drive adder with no problems, but IAC duty cycle and Idle adder have to be in check. I've also seen the load points change, and switch up timing pretty aggressively, so watch that as well.
Drew@DMP
Vehicle Information: All kinds of tuning poop
Unread postby fernando_221 » Tue Sep 26, 2017 10:11 am
Drew@DMP wrote:Hows your Idle air integrator doing at idle? whats your IAC duty cycle? I've done a lot of Fords with SCT and have used the A/C neutral adder or drive adder with no problems, but IAC duty cycle and Idle adder have to be in check. I've also seen the load points change, and switch up timing pretty aggressively, so watch that as well.
Please take a look at my log, it has idle air integrator and IAC duty cycle, at TS I turn on the AC.
IAC duty cycle is around 0.25 and integrator at -0.07.
fernando_221
Unread postby fernando_221 » Wed Sep 27, 2017 2:26 pm
I think I have good news, I think the idle problem was caused by a high min injector pusewidth.
It was at 1.4ms (0.00039) and now I set it to 0.5ms and all issues are gone, idle is perfect. The spec sheet for Deka 60 says 1.5ms and I was told by some tuners to don't go below 1.3ms. Is there any problem to use 0.5?
fernando_221
Unread postby decipha » Wed Sep 27, 2017 2:42 pm
i always set minpw to 0 in all my tunes
the siemens deka data is the absolute pulsewidth, you have to subtract the injector offset from that value
Ive never had a problem just setting it to 0
Unread postby fernando_221 » Fri Nov 17, 2017 9:40 am
Hey there,
With minpw set to 0 the idle is much better but I still have issues with idle and ac on.
Is this related to idle air? Spark? This is very annoying. I'll post a log soon.
Here is a video:
https://www.youtube.com/watch?v=Ga6cKnvRfp4
fernando_221
Unread postby jsa » Fri Nov 17, 2017 2:20 pm
Check your lambda vs lambse readings.
Cheers
John
EEC-IV GHAJ0 ANTI or COSY
Unread postby decipha » Fri Nov 17, 2017 2:58 pm
see post #2
Return to Speed Density Tuning
Users browsing this forum: strokerstang86 and 3 guests
