Harmonic balancer for blower
Rotating assembly specific sub-forum for balancing, pistons, rods, cranks, balancers. etc...
Unread postby Squishy » Fri Jun 16, 2017 2:05 am
Well toasted the 2nd oe style balancer, so who runs what?
I Found a Powerbond Race Series SFI Approved
PB1084SS for a reasonable r
Price but will it hold up? Only want to buy it once.
Double keyway? Is it necessary?
Not looking to run spacers or anything like I see some require
Squishy
Supporting Member 35
Vehicle Information: 91 5.0(302) Stock Shortblock, A9l, QuarterHorse, F-303, 1.7rr's, Edelbrock Performer 60379 Heads, TrickFlow-R Intake, BlowThrough PMAS MH30-HPX-E 3" MAF ,SD 80lb Injectors, Stock FPR@39PSI, GSS 340(255lph High Pressure) Fuel Pump, 70mm ThrottleBody, Vortech V3sci 10-rib 8" Crank 3.33 Blower Pulley, NX Meth Kit 625ml/min 300psi, Bosch BPV, 1-5/8" BBK Equal Length Headers, 2.5" X-Pipe, 2.5" Magnaflow Cat Back, Taurus 2 Speed Fan, No Smog Pump. No EGR. T-5
WBo2-C (AEM)
Re: Harmonic balancer for blower
Unread postby decipha » Fri Jun 16, 2017 2:49 am
how are they failing?
frpp makes a nice balancer, as well as bhj $$$
Unread postby Squishy » Fri Jun 16, 2017 8:30 am
I Broke a chunk off of the last one on the part that slides in the crank seal, this one the keyway is about 3/4inch wide now on the balancer side, I torqued it to spec when I threw it back together but apparently I need way more torque on it.
Hope the crank is okay gotta pull timing cover and see if there is still a keyway on the crank
Squishy
WBo2-C (AEM)
Unread postby Squishy » Mon Jun 19, 2017 10:07 pm
The woodruff keyway on the crankshaft is wallowed out pretty good closest to the balancer for about 1/2" maybe more,
thinking I need to change the crankshaft...
if that's the case may as well get a second woodruff key machined on the new crank and a blower specific balancer.
Squishy
WBo2-C (AEM)
Unread postby Squishy » Tue Jun 20, 2017 1:56 pm
Got the timing cover off cleaned the crank and took some better pics, does it look salvageable with a new woodruff key and balancer?
Balancer bolt had to have backed off. Is the woodruff key just for ensuring proper alignment on the crank or with a tight balancer bolt should the keyway be what's stopping the balancer from spinning on the crank?
Squishy
WBo2-C (AEM)
Unread postby decipha » Tue Jun 20, 2017 11:31 pm
i cant open jpgs on my mobile
the keyway is what centers the balancer and stops it from slipping on the snout
Unread postby Squishy » Thu Jun 22, 2017 3:39 pm
If you get a sec and could check the pics over, still don't know if it's salvagable some people say yes some say no, still undecided if it can work with this crank, new woodruff key and a new balancer
Squishy
WBo2-C (AEM)
Unread postby SlowBox » Thu Jun 22, 2017 6:06 pm
I would pull the crank sprocket, clean the shit out of that with brake parts cleaner and a steel wire brush, knock that old woodruff key out, and file it back so a new one will fit. There's still plenty of meat left on the snout, but obviously that balancer is decoration.
SlowBox
Advanced Tuner
5 speed, 3.73
GT-40P heads
Alex's Parts springs
10:1
FMS B303
GT-40 upper and lower
65mm TB
80mm Mk8 MAF
Decapped injectors
E85
Motorsport shorties
A9L/A9L2/GUFB
TunerPro v5
Moates QH v1.6
Unread postby decipha » Fri Jun 23, 2017 4:42 am
i just checked them out, I was say no that crank isn't gonna be up to the task, if it was n/a and not driving a blower off the snout it would be fine but with a blower it will fail just a matter of time
you can yank the crank and weld it up and machine it back, but that would prob be more work than just replacing it
Unread postby Squishy » Fri Jun 23, 2017 12:12 pm
Bah, still undecided which way to go ,have a powerbond sfi race balancer sittING at the parts store(single keyway standard size oil seal, CNC machined AISI 1045 forged steel hub) and a spare crank sitting in a block on the shelf.
Do I throw the spare crank in, single keyway powerbond balancer and do this as cheap as possible, (less than 200 usd total)
or have the spare crank machined for second woodruff(probably be at least a couple hundred bucks) and get an expensive blower balancer (cheapest I found was like 400 us, well over 650 canadian shipped duty and taxes)
If there is another issue with the bottom end thats not more than a couple hundred bucks to fix or some parts o have on the shelf shes just getting a dart iron eagle shortblock with my top end on it
im kind of leaning towards the cheaper fix because the expensive blower balancer will still have a 50oz balance and if i upgrade to the dart shortblock in the near future, id need another higher dollar balancer, the dart would be internal balanced and whatever balancer i get now will be a paperweight.
Do yall loctite the balancer crankshaft bolt? Blue? Red?
Decisions decisions
Squishy
WBo2-C (AEM)
Unread postby SlowBox » Fri Jun 23, 2017 1:02 pm
That's something you'll have to decide on your own. As for loctite, I do not use it on my balancer bolt because I've never had one back off. 3 ugga duggas and they've always been good to go.
SlowBox
Advanced Tuner
5 speed, 3.73
GT-40P heads
10:1
FMS B303
65mm TB
80mm Mk8 MAF
Decapped injectors
E85
Motorsport shorties
A9L/A9L2/GUFB
TunerPro v5
Moates QH v1.6
Unread postby Squishy » Fri Jun 23, 2017 1:16 pm
decipha wrote:you can yank the crank and weld it up and machine it back, but that would prob be more work than just replacing it
Doubt ill go this route but any more info on welding the crank? Have to be tigged prob? Would a mig suffice? Have to quench it once its welded?
Squishy
WBo2-C (AEM)
Unread postby decipha » Fri Jun 23, 2017 2:17 pm
i would tig it, i wouldnt recommend migging it as youd prob get a bunch of trash in the weld
you can toss an insulating blanket over it to help it cool down slower if u were so inclined to, I dont think it would be too critical though
Unread postby Squishy » Wed Jun 28, 2017 1:30 pm
A couple last pics before i pull the engine, pulled the woodruff key and cleaned the crank just to see what its like not as bad as i thought.
Anyone want to tell me not to pull the motor? Lol
Picked up a powerbond race sfi balancer
Squishy
WBo2-C (AEM)
Unread postby SlowBox » Wed Jun 28, 2017 2:44 pm
Man, I get that it's chewed up and the right thing to do is replace the crank, but I'd be hard pressed to not install that Powerbond and a matching woodruff key and send it. After all, it was the balancer that failed, not the crank or key.
SlowBox
Advanced Tuner
5 speed, 3.73
GT-40P heads
10:1
FMS B303
65mm TB
80mm Mk8 MAF
Decapped injectors
E85
Motorsport shorties
A9L/A9L2/GUFB
TunerPro v5
Moates QH v1.6
Unread postby Squishy » Wed Jun 28, 2017 2:57 pm
I'm on the fence about it.
the new balancer is a wicked tight fit, can feel it will need some persuasion to get it on, the old balancer slid on by hand basically, and no locktite on the bolt. So the key was doing all the work
Squishy
WBo2-C (AEM)
Unread postby SlowBox » Wed Jun 28, 2017 3:06 pm
Heat it in the oven and it'll slide right on. Don't risk fucking it up trying to use a BFH.
SlowBox
Advanced Tuner
5 speed, 3.73
GT-40P heads
10:1
FMS B303
65mm TB
80mm Mk8 MAF
Decapped injectors
E85
Motorsport shorties
A9L/A9L2/GUFB
TunerPro v5
Moates QH v1.6
Unread postby decipha » Wed Jun 28, 2017 3:28 pm
the balancer should be an interference fit, if it slid right on before it was faulty and not working as designed, surprised it didnt vibe or hurt the bearings
the only proper way to install a balancer is by press fitting it on using an installer tool, never put an impact or hammer on it
i dont recommend heating it up a good majority have internal rubber damper isolators that would cause failure, install it as it should be and go from there
Unread postby Squishy » Wed Jun 28, 2017 6:28 pm
It did have a very slight vibe for a while before this all went on, probably the beginning of the balancer losening off. thought it was coming from driveshaft.
No copper when i drained the pan and she was making good oilpressure whenbi put it in the shop
Squishy
WBo2-C (AEM)
Unread postby SlowBox » Wed Jun 28, 2017 8:45 pm
I don't think heating a balancer to 150 or 200 degrees would get it any hotter that when an engine is at operating temperature.
SlowBox
Advanced Tuner
5 speed, 3.73
GT-40P heads
10:1
FMS B303
65mm TB
80mm Mk8 MAF
Decapped injectors
E85
Motorsport shorties
A9L/A9L2/GUFB
TunerPro v5
Moates QH v1.6
Return to Rotating Assembly, Bottom End & Balancing
