Innovate MTX-L WB Output Settings - Solved
Unread postby yeastieBoB » Sat May 05, 2018 4:09 pm
The Innovate MTX-L WB has two analog outputs:
* #1 (yellow) is programmed to output between 0 V for an AFR of 7.35 (gasoline) and 5.0V for an AFR of 22.39.
* #2 (brown) simulates a typical narrow band oxygen sensor. The configuration is 1.1 V for an AFR of 14 and .1 V for an AFR of 15.
Questions:
- Should either of those output defaults be adjusted?
- The WB gauge display changes colors based on the AFR. Should the defaults be adjusted?
Green from 7.3 to 13.2
Yellow from 13.3 to 19.1
Red from 19.2 to 22.0
- What pin do I wire the narrow band sim to? Pin 27? I show that's the EVP sensor.
yeastieBoB
Re: Innovate MTX-L WB Output Settings
Unread postby decipha » Sat May 05, 2018 4:36 pm
no never change the defaults
narrow band simulator output is absolutely useless never use it
the egr valve position pin is the correct pin to use for the wideband output to log in the ecu
https://www.efidynotuning.com/config.htm
Unread postby yeastieBoB » Sat May 05, 2018 6:05 pm
Thanks, so I'll just turn off one HEGO then.
yeastieBoB
Return to Foxbody Tuning
Users browsing this forum: Google [Bot], KLRPMKN and 4 guests
