Try the Quarterhorse or stick with WMS SDS
Unread postby 89fast5oh » Thu Apr 26, 2018 5:13 pm
When I built my 408W last year I had no plans of swapping ECMs, I even had Ed Curtis grind a EFI friendly cam with a 114* lobe separation.
Then I came across a smoking deal on a Western Motorsports SDS speed density system. I installed it last fall and tried it out. I have gotten the car to run and drive very well but am fighting a terrible cold/first start condition.
No matter what I do I cannot get a nice startup from cold. It acts worse than a carbureted car. It has turned me off on using the system.
So now I figured that since I drove around a 435hp 351W with stock not tuned EEC-IV for 14 years, yes 14 years, that I would take the WMS SDS out and put the EEC-IV back in.
I have a Quarterhorse, chip, and burn2. I have read dozens of pages of info here on this forum and have even written a tune for my car based on Decipha's A9L2.
If I can't get the WMS SDS running well, am I dreaming thinking I can put the stock computer back in with the A9L2 and use the Quarterhorse to make adjustments?
89fast5oh
Vehicle Information: 1989 LX. 408W 10.7:1, FTI hyd roller .622"/.608" int/exh, AFR 185s, Edelbrock Victor EFI 5.8, 47lb injectors, 75mm MAF & throttle body, 1 3/4" long tubes, 2.5" full exhaust, TKO600, 4.10s.
Re: Try the Quarterhorse or stick with WMS SDS
Unread postby decipha » Fri Apr 27, 2018 12:16 pm
the a9l2 is mass air, sounds like you had a speed density setup
if your swapping ecus its dumb to go to the ancient and old fox era ecus much better off going to the 94-95 mustang 5.0 cbaza ecu as it has far greater control especially idle
if you have the speed density ecu just slap that back in, i wrote some idle code for the SD ecu's to tame the idle, it wont be perfect but significantly better than what the speed density ecu allows
Unread postby 89fast5oh » Fri Apr 27, 2018 1:09 pm
decipha wrote:the a9l2 is mass air, sounds like you had a speed density setup
I should have explained better. Car was a 1989 Mustang 5.0 with mass air. I got a good deal on the WMS SDS so I thought I would try that. I am not liking it so I will swap back to the Ford EEC-IV A9L mass air.
89fast5oh
Unread postby 89fast5oh » Fri Apr 27, 2018 1:18 pm
I guess thread doesn't matter really anymore because I started to swap back to the stock computer this morning.
89fast5oh
Unread postby decipha » Fri Apr 27, 2018 1:33 pm
why would you swap from the mass air ecu to an older speed density setup?
Unread postby 89fast5oh » Fri Apr 27, 2018 2:12 pm
decipha wrote:why would you swap from the mass air ecu to an older speed density setup?
I swapped because at the time I didn't know about the moates quarterhorse and there was no one within a few hundred miles that would even look at it.
89fast5oh
Return to Foxbody Tuning
