DASPTO vs DASMIN
DASPTO vs DASMIN
Unread postby 89FiveOh » Fri Mar 02, 2018 4:22 pm
Hello,
Can someone be specific on where to start first regarding high rpm de-clutch or the dreaded engine conk coming to a stopsign? No theory on the matter but just plain and to the point.
My current scalar setting:
DASPTO= 0.0901 lb/min
DASMIN= 0.0938 lb/min
Dashpot decay:
0.75 - 0.0625
0.64 - 0.0449
0.45 - 0.0071
0.35 - 0.0020
0.062 - 0.0029
While idleing, rpm settles in nicely
Declutching coming to a stop, falls so fast it cant catch it.
Is the Y-axis the time part of the decay?
Is the X-axis the amount to decay each time interval?
How would you pros adjust if er’thing else in the tune is on point?
How bout FN824 - ISC GAIN MULTIPLIER vs RPM?
Thanks in advance.
89FiveOh
GUFB A9L
Binary Editor/EEC Anaylyzer
Innovate MTX-L PLUS
MOATES QuarterHorse
308
Custom Cam (HR)
AFR 165, 58cc
BBK 75mm (24lb/hr calibration) MAF
5 speed
3.73 gears
NA
Full length BBK headers with H-pipe thru Flowmaster mufflers
Re: DASPTO vs DASMIN
Unread postby 89FiveOh » Fri Mar 02, 2018 5:17 pm
And one other thought.
Whats the cause of the sudden rapid rpm drop while coming to the stop? I would suppose the TB closing literally creates a vaccum which has a binding effect on the rpms and chokes it out. The addition of the ISC air simply eases the vacuum bind. Kinda like sticking your hand on a vacuum hose and then removing it. Surely its mainly the air thats the maintaining factor in a declutch scenerio and fuel is basically being abandoned?
Is DASPTO the ‘air’ that keeps it from choking down?
More DASPTO = faster RPM speed to overcome the vacuum conk
89FiveOh
GUFB A9L
Innovate MTX-L PLUS
MOATES QuarterHorse
308
Custom Cam (HR)
AFR 165, 58cc
5 speed
3.73 gears
NA
Unread postby decipha » Fri Mar 02, 2018 5:26 pm
the dashpot write up on the homepage will give u all the info u need
for starters, go set damin to .35 so it has more dashpot on decel
go divide the dashpot decay by 2
that should fix it to let u start dialing in dashpot
Unread postby 89FiveOh » Fri Mar 02, 2018 5:36 pm
Exactly the reply I asked for. Thanks.
No insight on the scenerio I mentioned above? Does a declutch scenerio conk the engine because of the rpm robbing force of the vacuum caused by closed throttle and the ISC doesnt supplement enough air to overcome it?
So when I add more DASMIN, its the additional air required to offset the vacuum force?
89FiveOh
GUFB A9L
Innovate MTX-L PLUS
MOATES QuarterHorse
308
Custom Cam (HR)
AFR 165, 58cc
5 speed
3.73 gears
NA
Unread postby decipha » Sat Mar 03, 2018 5:30 am
no has nothing to do with the throttle or vac its simply mechanics, an engine needs dashpot to maintain stability
Unread postby indy2000 » Sun Sep 30, 2018 11:49 am
89FiveOh wrote:And one other thought.
did you rid the 'conk'?
indy2000
Vehicle Information: gr-40 89Gt, A9L, BE, LC-1, KB2200 flowzilla,90mm TB, 90mm LMAF, 42#, stock cam, y303 heads.
Return to Foxbody Tuning
