wideband o2 plx dm6 conversion
Unread postby 89mustangcoupe » Sat May 27, 2017 5:12 pm
im looking for a conversion in the adx editor for the wbo2 sensor so i can log the correct afr or lambda when dataloging in tunerpro
89mustangcoupe
Vehicle Information: 1989 ford mustang lx coupe a9l ecu, moates quarter horse, plx dm6 wideband,tuner pro rt, 302 stock block,9:9:1 CR sealed power forged pistons, eagle I beams, eagle crank, gt40p heads with mild porting on exhaust, crane conical valve springs ,1.7 crane cams cobra rockers, Anderson n-21 cam, Vortech V1 S-trim, FMIC, Siemens Deka 60lb injectors, pro products AFPR, PMAS HPX-E Blow thru MAF, typhoon professional products intake with 1 inch spacer, bbk 75mm tb with egr delete,msd blaster coil,accel distributor module, Mallory hyfire 685, T5 trans, strange 35 spline axles and full spool with 4:10 gears, FMS shorty headers bbk x pipe, flow masters to tail pipes, Autolite 103's
Vehicle 2 Information: 89 Camaro RS 305 TBI Auto Stock
Re: wideband o2 plx dm6 conversion
Unread postby decipha » Sat May 27, 2017 6:40 pm
post the widebands transfer and we can work out the fomula
the transfer should be posted in the manual that came with it, or a google search should find it
Unread postby 89mustangnotch » Sat May 27, 2017 10:55 pm
I found the some info on gauge says stoich = 2.35v measures for 10-20 afr or 0.68 - 1.36 lambda
89mustangnotch
Vehicle Information: 89 mustang lx 302 5 speed a9l gt40p heads ported with conical valve springs, Anderson n-21 cam, 1:7 cobra crane rockers,typhoon intake 75mm bbk tb, bbk shortys with bbk x pipe
Unread postby 89mustangnotch » Sat May 27, 2017 11:24 pm
I'm using the 735 + (x / 4267) conversion hooked to the EVP signal at ecm and it seems to be off a little as I believe stoich 14.7 is 2.5 volts on this conversion
89mustangnotch
Unread postby 89mustangcoupe » Wed May 31, 2017 11:41 pm
any idea on conversion
89mustangcoupe
Unread postby SlowBox » Thu Jun 01, 2017 12:26 pm
I'll draw one up when I get to my laptop.
SlowBox
Advanced Tuner
5 speed, 3.73
GT-40P heads
Alex's Parts springs
10:1
FMS B303
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
A9L/A9L2/GUFB
TunerPro v5
Moates QH v1.6
Unread postby Bad86capri » Mon Jun 05, 2017 3:45 pm
89mustangnotch wrote:I found the some info on gauge says stoich = 2.35v measures for 10-20 afr or 0.68 - 1.36 lambda
im using a plx and thats the chart i used. seems to work fine.
Bad86capri
Vehicle Information: 86 Capri T-Top. Oxford white, grey trim and canyon red interior. 306 with twisted wedge heads, Anderson b3 cam, holley systemax intake, ev6 30lbs inj., c&l 80mm maf, 70mm tb, longtube headers. Im currently using a plx wideband mounted in the driverside header. Tuning with moates quarterhorse and BE although sometimes i play around with Tunerpro
Unread postby 89mustangcoupe » Sun Jun 11, 2017 3:32 pm
is that in tunerpro or BE I use only tunerpro
89mustangcoupe
Unread postby decipha » Mon Jun 12, 2017 2:26 am
the equation is right there in the screen shot on the plx output chart
2 * volts + 10
for greater understanding, the following is from the logging inputs write up on the homepage under reference >> wiring
1.36 - 0.68 • Max Lambda Measureable - Min Lambda Measureable = Z == 0.68
0.136 is 0.68/5 • Z / 5 = Y ;{Max Voltage Output - Min Voltage Output (5v - 0v)}
• ( {Y} * (X / 12800) ) + Min Lambda Measureable ; Note: x/12800 is to convert 16 bit ad channel to voltage
thus the equation comes out to,
(0.136 * (X / 12800) ) + 0.68 which comes out to be the same as
2 * volts + 10 / 14.7
its already in the GUFX adx as WBo2-C, just right click on it and select it from the drop down
for reference
http://www.efidynotuning.com/config.htm
Unread postby 89mustangcoupe » Sun Jun 18, 2017 8:40 pm
can u post the gufb.adx your talking about I cant right click is just shows values when I right click on the dash of wb02
89mustangcoupe
Unread postby decipha » Sun Jun 18, 2017 11:24 pm
scroll down to the bottom of that list and youll see wbo2-c
Unread postby 89mustangcoupe » Mon Jun 19, 2017 12:43 pm
thanks had wrong ADX FILE
89mustangcoupe
Return to Foxbody Tuning
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
