306 Build
306 Build
Unread postby theskitzofrantic » Fri Mar 24, 2017 4:19 pm
Trying to get my car back on the road but not having much luck... Was told I need a tune, anybody able to tell me if that's true.
Current build:
306
E303 Cam
1.6 Rockers
Trick Flow Heads
24lb injectors
Ford Explorer NON EGR upper and lower Intake
70mm Throttle Body and spacer
75mm MAF calibrated for 24lbs
BBK CAI
BBK Equal length shorty's
255lph Holley Fuel Pump
theskitzofrantic
Re: 306 Build
Unread postby SlowBox » Fri Mar 24, 2017 6:31 pm
Welcome to the forum. The heads definitely need compensated for and you're out of injector. Are you wanting to try and tune it yourself?
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: 306 Build
Unread postby Squishy » Fri Mar 24, 2017 9:24 pm
It should run fine without a tune since the Maf is calibrated, obviously better with a tune but should be fine without, I ran an E cam performer headed 30lber and calibrated Maf combo for years without a tune, only tuned it since the supercharger
Squishy
Supporting Member 35
Vehicle Information: 91 5.0(302) Stock Shortblock, A9l, QuarterHorse, F-303 (4*A), Crane Gold 1.6rr's, Edelbrock Performer 60379 Heads, TrickFlow-R Intake, PMAS-HPX-E 100mm Housing MAF, ACT Sensor Mounted In Discharge Tube Before Throttle Body, AFM 4" Power Pipe ,SD 80lb Injectors, Stock FPR@39PSI, GSS 340(255lph High Pressure) Fuel Pump, 70mm ThrottleBody, Vortech V3sci 10-rib 8" Crank 3.33 Blower Pulley, Vortech Mondo BPV, NX/Snow Stage 1 Meth Kit - 625ml/min Nozzle, 1-5/8" BBK Equal Length Headers, 2.5" BBK H-Pipe, 2.5" Flowmaster Origional 40 Cat Back, Taurus 2 Speed Fan, No Smog Pump. No EGR. T-56 Magnum (Close Ratio)
*WBo2-C*
Re: 306 Build
Unread postby theskitzofrantic » Sat Mar 25, 2017 8:05 am
I was thinking about getting either a BAMA 4bank or Moates QH because i want to delete the egr and all of the smog functions.
theskitzofrantic
Re: 306 Build
Unread postby theskitzofrantic » Sat Mar 25, 2017 8:06 am
I just got the 24# injectors/heads and intake along with maf & throttle body installed are 24's not big enough?
theskitzofrantic
Re: 306 Build
Unread postby theskitzofrantic » Sat Mar 25, 2017 8:22 am
As she currently sits.....
theskitzofrantic
Re: 306 Build
Unread postby SlowBox » Sat Mar 25, 2017 8:45 am
The QH will give you more control over the ECU as it's a more powerful piece of equipment. Not sure about a price difference, but the Moates chip is $250 brand new. As for the 24s, I maxed a set with stock heads. Have you been able to run the car since you got it all put together?
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Stock cam
9.7:1
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: 306 Build
Unread postby theskitzofrantic » Sat Mar 25, 2017 9:26 am
I have not tried with the 24# injectors ,maf,throttle body....... I put the heads and intake on the motor with stock maf,19# injectors & stock throttle body and it ran like crap.
theskitzofrantic
Re: 306 Build
Unread postby red5.0fogger » Sat Mar 25, 2017 12:43 pm
The heads cam and intake add around 100 HP so there needs to be more fuel from somewhere. Throw in those injectors or even bigger ones and tune it.
Premium Member
Re: 306 Build
Unread postby SlowBox » Sat Mar 25, 2017 1:08 pm
Yep. The 24s may not lean out since you're using a GT40 upper and lower, but they'll be close. Regardless, it needs adjustments you're not gonna be able to compensate for with 'calibrated' parts.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Stock cam
9.7:1
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: 306 Build
Unread postby decipha » Sat Mar 25, 2017 1:27 pm
theskitzofrantic wrote:I have not tried with the 24# injectors ,maf,throttle body....... I put the heads and intake on the motor with stock maf,19# injectors & stock throttle body and it ran like crap.
something isnt right then, with the stock injectors and maf it should run just as good as a stock engine
check out the pre tune info and make sure nothing is off
http://efidynotuning.com/pre.htm
Name: Michael Decipha Ponto
06 Chrysler 300 AWD - Sharifa
Re: 306 Build
Unread postby theskitzofrantic » Sun Mar 26, 2017 12:16 pm
Anybody have an idea roughly what kind of horse power I should expect from this engine?
theskitzofrantic
Re: 306 Build
Unread postby decipha » Sun Mar 26, 2017 4:53 pm
308rwhp
Re: 306 Build
Unread postby theskitzofrantic » Fri Apr 14, 2017 7:44 am
So....I finally got the car running and it seems to be okay, not sure I like the cam choice because of the in town driving. Still want to get a wide band installed and do some tuning because im sure it can be better....the suspension is shot so that next on the list.
theskitzofrantic
Re: 306 Build
Unread postby decipha » Sat Apr 15, 2017 2:46 pm
nice, the biggest part of the battle is getting it going everything is down hill from there
