Timing help
Timing help
Unread postby 91foxgt » Sun Jan 14, 2018 8:40 pm
I have a stock 91 mustang gt with the A9L2 tune. I didn't have a timing light, so for the longest time i was running the tune with 14 degrees of timing when it asked for only 10. Finally my timing light came in the mail today so i set it to 10 degrees and went on a test drive. Immediately i can feel a deference. It doesn't pull as hard as it did with the 14 degrees. I want to set it back to 14 but im afraid i can damage engine if i do. Anybody know if it is ok to set it to 14 degrees?
91foxgt
Premium Member
Vehicle Information: 1991 ford mustang gt 5 speed
Re: Timing help
Unread postby decipha » Mon Jan 15, 2018 5:17 am
part of tuning is dialing in timing, if it lost power with those 4 degrees out then go to the spark table and add 4 degrees back to it
Re: Timing help
Unread postby 91foxgt » Mon Jan 15, 2018 6:43 pm
thanks. ill try it out.
91foxgt
Premium Member
Re: Timing help
Unread postby 91foxgt » Mon Jan 15, 2018 6:51 pm
im trying to find the spark table but there are many tables for spark. is it spark altitude table or spark extended?
91foxgt
Premium Member
Re: Timing help
Unread postby decipha » Mon Jan 15, 2018 7:13 pm
look under the tuning menu >> spark
its the only spark table filled in should be very obvious
Re: Timing help
Unread postby 91foxgt » Thu Jan 18, 2018 9:56 am
Update: I added 2 degrees to the entire table to be on the safe side but the car is still weird. I've noticed it sounds completely different (good or bad, i dont know). Im going to take away the 2 degrees i added since i dont know if it can cause damage to my motor.
91foxgt
Premium Member
Re: Timing help
Unread postby SlowBox » Fri Jan 19, 2018 9:30 pm
+/- 2° won't damage a stock motor. How is it acting weird?
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: Timing help
Unread postby 91foxgt » Sat Jan 20, 2018 7:25 pm
Well guys i have to admit, i made the stupidest mistake i can possibly make. So last week when i was adjusting the timing to 10 degrees, i followed the steps and adjusted it with the spout connector removed then tightened everything up while the timing was set. Turns out that i forgot to plug the spout connector back!!!! :lol: so i was driving the car all week with it off. i was revving it out too, so my fingers crossed i didn't damage anything. I just jumped the connector with a paper clip for now since the spout connector is probably gone somewhere on the highway lol.
91foxgt
Premium Member
Re: Timing help
Unread postby Boostcoupe » Sat Jan 20, 2018 7:47 pm
with the spout out it was just locked at what you set it at with no advance, so it was locked at 10*. i dont think it would hurt anything that low.
Boostcoupe
Vehicle Information: 86 tbird TC, 2.3t, lb3, moates qh. 3" exh from turbo back, 18psi, esslinger cam gear@ 4* ret
Vehicle 2 Information: 89 mustang 5.0, A9L, moates qh. ported 3bar gt40's, gt40 intake, 65mm tb, 24lb ev6 inj, 76mm c&l cal for 24lb
fti cam, bbk shorties, o/r hpipe, t5, 4.10's, best time so far 12.90@106 1.95 60ft.
Vehicle 3 Information: 89 third sc, 3.8, moates qh. all stock except some eibach springs
Re: Timing help
Unread postby 91foxgt » Sat Jan 20, 2018 8:02 pm
car seems to run fine with no issues. Like you said, it probably didn't hurt anything. Thanks.
91foxgt
Premium Member
Re: Timing help
Unread postby decipha » Sun Jan 21, 2018 7:00 pm
nope it won't hurt nothing just won't make any power
A few years back I had a guy check timing at the track to verify it was at 10 dbtdc, he checked it and it was, he then closed the hood and neglected to plug the spout back in, car ran an 11.1, much much slower than the 10.5 it was running on the prior passes, amazing how much power 7 degrees can make
Return to Foxbody Tuning
